Old 12-20-2010, 12:52 PM   #1
roger999's Avatar
Default picco evo4 + nova 2630 pipe
like in title, i dont know will it work? i mean i dont know why but when i try to fit nova pipe on picco gasket i can feel there some loose... Should be that tight? Can i use nova gasket? When i put nova gasket i didnt feel eny loose on it, but i sont know what will be after few tanks...?
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 12-20-2010, 01:29 PM   #2
Seisick's Avatar
nova header on picco engine use a special gasket which only ofna offers, kamikaze rc has them for sale
http://www.kamikazetoysandhobbies.co...php?prod=51997
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 12-20-2010, 05:53 PM   #3
I have 3 of them if you wanna buy them off me, $5 (includes postage) and its all yours. I dont need them since I run a Picco system on my Evo3.
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 12-20-2010, 07:07 PM   #4
abi
Off topic DJ, where is a good online place to source Picco Evo 3 conrods? Part number or batch numbers for stronger/strongest ones if thats possible?
Cheers
Adrian
Team Magic tragic. G4S RTR, G4S, G4S+Evo, 3 x RS09's.
OS Speed, Spektrum.
abi is offline   Reply With Quote
Old 12-20-2010, 09:29 PM   #5
Very good question!! As far as memory serves me, you might be able to get some from rcmart, or from Sam @ Kamikaze Toys and Hobbies.
I dont think they are supporting it any more since the rods are as good as paperweights I still have only one spare left after I finish getting rid of my Evo3's pinch just around TDC, still can't turn it over by hand and it's got an extra 0.1mm shim in it. Secret of mine is that the piston is from my first Evo3 modified from AB Mods, and the sleeve is from a 2nd stock one I got. Perfect fit for each other, and I copied over the mod but added a little more timing to the Boost port.
Old 12-21-2010, 01:45 AM   #6
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Sam no longer has the rods in stock for the .12 evo3. He's working on getting some from a source outside US.
To the OP, the best pipe for the Evo 3 is the 2651 Picco pipe. Using anything other than that will not get you good results.
YR4Dude is offline   Reply With Quote
Old 12-21-2010, 08:44 AM   #7
GREGORY!'s Avatar
one off topic question.
what do you do in your motors?first picco's then rb that you have not run in right.
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 12-22-2010, 12:54 AM   #8
Not sure what you are asking.
But I'll answer the way I see how it is asked.
First engine was a modified Picco Evo3.
Then when that went out, I tried a stock Evo3. That went out the window even faster than the first one!! (2 months or so)
Then I got an RB T10 - absolutely loved the power and tuning of it! Actually had to make it rich (either the bottom or top) to make it more controllable.
BUT, with these engines, I thought I had broken them in correctly, but I didn't monitor the temps/keep them high enough after the 3-4 tanks or so, so I believe it started off well but then because the temps were not high enough to break-in properly, it actually messed them up by basically doing this:
Because the sleeve expands faster than the piston itself, in the beginning it was fine/where it would probably be at it's maximum diameter. After the 3rd/4th tank, that diameter was naturally reduced due to the lower temperature and because it was much tighter, the piston probably wore away too much of the sleeve and so the ability to create a seal was lost once more heat got into it.
Now that I strongly believe that this is the case, I swapped out the unmodified sleeve from the 2nd Evo3 and used the piston from the first modified Evo3. The sleeve was just as tight as a brand-new set, and now I am STILL in the process of getting rid of that pinch. I still can't turn it over by hand without hitting the pinch almost at TDC and this is now the 4th tank since "Frankensteining" it. Plus I modified the stock sleeve using the same measurements from the first Evo3, but I increased the timing on the boost port (by mistake, but it sure does fly!!!)
Old 12-22-2010, 09:56 AM   #9
YR4Dude's Avatar
Just noticed that the OP posted for an Evo4. The 2651 pipe is still the best. I got a 2651 pipe with my Evo4 Edo combo. For the Picco .12s there is no other pipe that works better.
Old 12-23-2010, 11:04 PM   #10
gfilos's Avatar
if the nova gasket feels tighter, use this instead of the picco one. But as
other people are saying, do yourself a favor and buy the 2651 pipe. Or at least
if you could find an older picco/mega #2607 or idm #2617 pipe set at a lower price, with the idm being a slightly better choice for the evo4 (gives more top-end).
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
