Old 02-23-2005, 03:04 AM   #91
speedy2's Avatar
sorry I just found out about this site
happily I did !
I use 16% RB fuel ready made
the buggy is the sportwerks Mayhem
another question:
my hobbyshop who doesn't even know about turbo plugs !
gave me a #3 plug to run(-in), is that alright
I own also # 5 and #6 RB plugs now
thanks again
I just picked up again after 10 years so....
speedy2 is offline   Reply With Quote
Old 02-23-2005, 03:30 AM   #92
speedy2's Avatar
I'm a bit worried
because I don't see a o-ring shutting off above where the carburator comes fixed.
won't it take air there ??
I installed a micro fine o-ring there just in case...
Old 02-23-2005, 05:22 AM   #93
Nitro Tech
dino.tw's Avatar
Originally posted by speedy2
I'm a bit worried
There is only one o-ring on the crankcase below the carburetor to seal up the air. It no need another o-ring if the sealing o-ring is in good condition.
If you use 16% nitro,you can use 0.3mm head shim. Want more punch use 0.2mm shim. If 0.2mm burn your plug(coils pushed),change back to 0.3mm.
Use long body normal plug #5. It has the widest usable range.
If you want to use Turbo head button,use #6 turbo plug.
Thank you,
Dino
dino.tw is offline   Reply With Quote
Old 02-23-2005, 05:27 AM   #94
speedy2's Avatar
wil the #3 plug be ok for running-in ??????????????
Old 02-23-2005, 05:40 AM   #95
Nitro Tech
dino.tw's Avatar
It is good for break-in process. The engine will not that easy to be shut down under rich setting.
Old 04-02-2005, 09:35 AM   #96
Hi.
Just blew up a plug today.
What plug would you suggest for air temp 10 celsius, 25% nitro this is for break-in
Mr.No1 is offline   Reply With Quote
Old 04-03-2005, 04:17 AM   #97
Nitro Tech
dino.tw's Avatar
Originally posted by Mr.No1
Hi.
What plug be blown up?
Please try #4 long body plug.
Old 04-03-2005, 05:05 AM   #98
OS A3 but I will test #4 long body.
Old 04-08-2005, 04:43 AM   #99
speedy2's Avatar
can I run the D.21 without an carburator insert ?
or is it better to use one?
Old 04-08-2005, 11:12 AM   #100
i fired up a new 21 for a friend and the engine started backwards.
Restarted it and was OK but the needle settings are way off.
What are the factory settings and why did start backwards?
sts2000 is offline   Reply With Quote
Old 04-12-2005, 09:33 AM   #101
Nitro Tech
dino.tw's Avatar
Most of the cases are happened when the starter run the wrong way. A backwards engine will flameout when you try to open the throttle.
Old 04-23-2005, 04:23 AM   #102
speedy2's Avatar
first time my d.21b motor started fine
today second time NO WAY to start
what can be the problem ? plug is ok
how much needle spins out from closed for high needle 3,5 ?
could there be deposit of oil in the housing strangling the engine ??
Old 04-23-2005, 08:34 AM   #103
Nitro Tech
dino.tw's Avatar
The racing setting is around HSN 1.5~2 turns out. The LSN is aroung 3 turns. The fuel will deteriorate after 6 months.
Old 04-23-2005, 12:23 PM   #104
speedy2's Avatar
whoops!
I turned 3.5 out
Old 05-15-2005, 02:14 AM   #105
I need some bearings but I can't find which size they are ? What are the dimensions of the front/rear bearing?
Buggy engine: OS MAX-21 RG-X or STS D21B? drakuli Nitro Off-Road 8 10-03-2009 04:32 PM
NEW STS D21B MKII factory tuned Buggy engine rregl0612 R/C Items: For Sale/Trade 10 06-09-2008 02:10 PM
STS D21B Roto start? Grindinghalt Electric Off-Road 1 05-31-2007 04:23 PM
STS D21B NeRacer Australia For Sale/Trade 2 05-31-2007 04:58 AM
STS D21T & D21B porter Electric Off-Road 31 01-16-2007 01:30 AM
