Old 01-08-2005, 01:25 PM   #76
Thats dirty? HA HA HA HA...
Here is dirty..
Dino: Attached is the pipe I think comes with all hyper 7's.. (for 20 SMOKE)
au_Nightmare is offline   Reply With Quote
Old 01-08-2005, 02:04 PM   #77
Default D21B First start
I just bought a D21B for my hyper pro.
What I am wondering is if the starter box will spin the engine since it is so tight. I have a 12V big motor starter box which i bought with my Hyper PBS and have been using it for both buggies.
Will it spin the STS engine?
sts2000 is offline   Reply With Quote
Old 01-08-2005, 02:30 PM   #78
I heated my engine up good with hair dryer and turned over with thunder tiger starter box didn't try without heating it...
Old 01-08-2005, 08:30 PM   #79
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Thanks Night
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-09-2005, 08:20 AM   #80
Nitro Tech
dino.tw's Avatar
Default Re: D21B First start
Loosen the plug about 1/2 turn may help. When the engine start screw it soon.
dino.tw is offline   Reply With Quote
Old 01-15-2005, 06:33 AM   #81
Fired up on my hyper starter box and all went well.
The high needle was way out but took it back to normal settings.
Its on its third tank now.. still going slow but the punch power it has is unreal. A value for money engine. Thank you STS.
Old 01-15-2005, 10:53 PM   #82
Nitro Tech
dino.tw's Avatar
Thanks for your support,too.
Old 02-20-2005, 01:36 AM   #83
banquer's Avatar
Hello every one, but this question is for Dino.tw
Here in my club, there is many people interested in D21B engine, and they need some information to buy about 5 o 6 motors for so many guys.
Are down power of this engine like Novarossi P5 o Sirio Kanay EVO 2 more or less?
What about high power?
In South of Spain (Granada), temp. are about 20 to 45, are the os#8 a good plug for this temp.?
What shims must to use with 25% of fuel?
Best regards from Granada (Spain).
banquer is offline   Reply With Quote
Old 02-20-2005, 02:48 AM   #84
Nitro Tech
dino.tw's Avatar
In South of Spain (Granada), temp. are about 20?to 45? are the os#8 a good plug for this temp.?
Dear Sir,
Sorry,I don't comment on other manufactories's products. I have no idea about P5 or Sirio. STS wish to produce the best MIT engines. From our product you can find our hard working. Please try one and you will see its different.
The weather is almost the same with Taiwan. OS plug is short body. But our engine fit with long body plug. If you want to us OS standard plug on D21B,remove the brass shim of the plug. Otherwise you will get low compression. About head shims,try 0.4mm(total) for 25% first.
Regards,
Dino
Old 02-20-2005, 06:34 AM   #85
banquer's Avatar
I'll try one of then for our club.
Which plug is recommended by your company for our country and the D21B engine then?
Regards.
Old 02-20-2005, 11:50 AM   #86
Nitro Tech
dino.tw's Avatar
Regards.
Any long body standard plug #5
Thanks,
Dino
Old 02-23-2005, 02:12 AM   #87
speedy2's Avatar
I'm somewhat confused
you say there are so many shimms in the D21b but in the manual it's stated not to use standard more then 16% fuel with standard set-up shimms?????!!
speedy2 is offline   Reply With Quote
Old 02-23-2005, 02:31 AM   #88
Where does it say that? Can't find that in my manual..
Old 02-23-2005, 02:44 AM   #89
speedy2's Avatar
the complete instruction manual from the net =
" before you install the button head, do not forget to install the proper number of compression gaskets. We suggest you use at least 0.3 to avoid hitting....
ok, I see, you should not place some shimms but take them out then, is it that ?....
it says:
0.3 : under 16%
0.4 under 20%
0.5 : under 25%
0.6 : under 30% nitro
but also use 10% oil in fuel
most fuel have only 8% or so ?????????????
Old 02-23-2005, 02:55 AM   #90
From page 1 - stock shims: 0.1mm(brass) + 0.2mm(brass) + 0.3mm(aluminum)
So yes you need to remove if nitro 25% or less - I am running .2 with 15% nitro.
My fuel I have been running has 15% oil, 10% syn and 5% castor. Guess it depends how long you want engine to last Vs Performance
(My next bottle is 18% , have to see how it goes... )
Buggy engine: OS MAX-21 RG-X or STS D21B? drakuli Nitro Off-Road 8 10-03-2009 04:32 PM
NEW STS D21B MKII factory tuned Buggy engine rregl0612 R/C Items: For Sale/Trade 10 06-09-2008 02:10 PM
STS D21B Roto start? Grindinghalt Electric Off-Road 1 05-31-2007 04:23 PM
STS D21B NeRacer Australia For Sale/Trade 2 05-31-2007 04:58 AM
STS D21T & D21B porter Electric Off-Road 31 01-16-2007 01:30 AM
