Old 10-02-2004, 07:08 PM   #31
Has anyone ran this engine , how does the bottom end power compare to a P5 or OS .21 ? ALso what pipe combo and glow plug seems to work , if it performs as well as it looks it would be a great alternative to the normal .
Eddie is offline   Reply With Quote
Old 10-03-2004, 10:55 AM   #32
Nitro Tech
dino.tw's Avatar
Originally posted by au_Nightmare
woohooo
Thanks for your support! Stephen<kiss>
dino.tw is offline   Reply With Quote
Old 10-03-2004, 11:06 AM   #33
Nitro Tech
dino.tw's Avatar
This engine has smooth powerband. A little less bottom end compare to P5,but it has very good top end. Also it is very affordable http://www.projectzen.net/page5.html
Old 10-11-2004, 01:05 AM   #34
Can anyone suggest a pipe that works well with this engine. From what I see the STS pipe don`t have a efra, imfar mark, so I can`t use it in a race.
sturla is offline   Reply With Quote
Old 10-11-2004, 01:10 AM   #35
Dino,
I knew you would make a .21!
So you ran it in your 1/8th on-road, how did you like it? Are you planning for an on-road version? The price alone is worth it! How does the life of the rod compared to the Rossi engines. We can go a whole season on a rod and not be concerned, unless we have an over rev, but normal racing, never really look at it much, and haven't popped one yet.
I wish you could see my little Kelsey run her car, you would be most impressed, makes a few grown men very unhappy at times.
Her last race she put the boots to the boys and had her first ever win, very proud daddy!
Dino, you take care, and enjoy your new baby. They are truley a joy!
Smitty
smitty is offline   Reply With Quote
Old 10-11-2004, 09:46 PM   #36
Nitro Tech
dino.tw's Avatar
Originally posted by smitty
Dino,
I wish you could see my little Kelsey run her car, you would be most impressed, .
Smitty
makes a few grown men very unhappy at times.... hahaha.....
My son will catch up with your little Kelsey soon. I found a good teacher for him already...
Old 10-11-2004, 10:02 PM   #37
I see,
Guess I need to call in the troops,
Old 10-24-2004, 02:49 AM   #38
Dino you have PM
fearsome is offline   Reply With Quote
Old 11-19-2004, 04:13 PM   #39
TWF8 have part of the review up of the D21B...
http://www.twf8.ws/new/tech/engine/s.../sts-d21b.html
au_Nightmare is offline   Reply With Quote
Old 11-21-2004, 12:26 PM   #40
Default D21b needle settings
Anyone know the standard needle setting for the D21B? Also a link for parts in the USA.
pixels_cs is offline   Reply With Quote
Old 11-25-2004, 01:57 AM   #41
Many manufactures tend to post the BHP of each engine although many say it is not correct.
However they do know the RPM. How come STS does not mention the RPM"s on their engine spec sheet.
sts2000 is offline   Reply With Quote
Old 11-26-2004, 02:08 AM   #42
Nitro Tech
dino.tw's Avatar
Because we think there is no sense.
If we use 40% nitro even more nitro,no loading,test it under air conditioner....etc. And tell you the max.rpm is 50,000rpm.Is it make sense?
Old 11-26-2004, 02:29 AM   #43
Yes you gotta ask the question - how do they come up with these RPM values?
Unloaded engine? if loaded how much load? how much Nitro? Oil? How long can it sustain the rated RPM?
Best RPM/BHP measurement is on the track.
Old 11-26-2004, 03:58 AM   #44
Normally the factory suggests the nitro % for each engine and according to that the give the rpm value. For sure it cant be accurate and will differ according to climates.
Old 11-27-2004, 02:31 AM   #45
sts2000, Listen to dino - his the master
Example of why it it does not really matter.
Lets look at the specs of the OS .18 TZ engine -
SPECS: Displacement: 0.183 cu in (3.0cc)
Bore: 0.629" (16.0mm)
Stroke: 0.590" (15.0mm)
Practical RPM: 3,000-34,000
Output: 1.8ps @ 29,000 RPM
Now when RCZONE tested it -
2.28 horsepower at 30,500 rpm and "as high as 42,500 rpm under light loads"
The figures differ there somewhat...
Buggy engine: OS MAX-21 RG-X or STS D21B? drakuli Nitro Off-Road 8 10-03-2009 04:32 PM
NEW STS D21B MKII factory tuned Buggy engine rregl0612 R/C Items: For Sale/Trade 10 06-09-2008 02:10 PM
STS D21B Roto start? Grindinghalt Electric Off-Road 1 05-31-2007 04:23 PM
STS D21B NeRacer Australia For Sale/Trade 2 05-31-2007 04:58 AM
STS D21T & D21B porter Electric Off-Road 31 01-16-2007 01:30 AM
