Old 12-04-2010, 05:22 PM   #1
bluer322's Avatar
Default Capricorn Lab E01 .12 Engine Or Murnan M3
I need a motor for the Fla. Winter Nats. I was thinks of getting one of these 2 I need a little help. I'v seen both run, aleast run past me anyway.
T. Nicholson
Murnan Modified Motors
Matrix Tires
Serpent, 748tq
bluer322 is offline   Reply With Quote
Old 12-04-2010, 05:44 PM   #2
DS Motorsport's Avatar
I've been running the Lab E01 WC engine for about half a season now and I've been very happy with the power it delivers. The last two years I've had nothing but really fast engines but this was something else.
It makes the most mid and top end power of all the engines I've had and raced against, including Murnan's.
I found it a bit harder to tune then most engines, but this is something which is inherent to a highly tuned engine.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 12-04-2010, 05:57 PM   #3
bluer322's Avatar
What pipe would you recommend with that.
T. Nicholson
Matrix Tires
Serpent, 748tq
Old 12-04-2010, 06:09 PM   #4
The Capricorn 2662, best pipe currently available for Nova engines.
On every engine I tested it, it gave the engine more mid and top end power.
P1-RC.com
Old 12-04-2010, 06:36 PM   #5
bluer322's Avatar
thanks
T. Nicholson
Matrix Tires
Serpent, 748tq
Old 12-05-2010, 12:54 AM   #6
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
The insulator of the carb has a lot to do with this...
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 12-05-2010, 07:27 AM   #7
Grinder's Avatar
Strange. I have found the M3 to have more bottom, and midrange power with similar top speed to the balanced Capricorn .12 engine. The M3 also got slightly better runtime. I also had to clutch the Capricorn engine very hard. Who's M3 did you see running? Was it V1, or V2 M3 engine? M3V2 is wicked. It has been out for about 6 months now. A couple of M3V1 engines had a faulty O-ring in the carb. This caused a loss in power, and tuning. I thought I fixed all the bad ones. Maybe I missed the one you saw. V2 does not have this problem. The M3 is also very easy to tune.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 12-05-2010, 09:21 AM   #8
bluer322's Avatar
? does the M3 v2 come prebroke in. And whats the recommended pipe for that motor.
T. Nicholson
Matrix Tires
Serpent, 748tq
Old 12-05-2010, 12:21 PM   #9
The Lab has less bottom end compared to an M3 or flash, but when you combine this engine with a Capricorn clutch this is solved instantly.
Most of the stock clutches simply aren't good enough for highly tuned engines.
Plus mid end makes or breaks a racing engine if you ask me, and the Lab has loads of mid end power. When it hits second gear it's bye bye everyone, especially with the Capricorn Lab car.
Both M3's I saw didn't make 5 mins, I can make 5:20 without performing any special tricks, but this can be down to driving style.
I think both engines were still V1 versions because both drivers had it from the start of the season.
But I haven't driven an M3 myself (the .12 version, did drive the 3.2L version ), I was actually planning to use them for the 2010 season because of all the enthusiasm on this forum but when I saw the other M3's I wasn't impressed, disappointed actually.
The guy who bought one was disappointed as well.
I pm'd you which M3's I saw since both of these drivers don't visit this forum as far as I know.
P1-RC.com
Old 12-05-2010, 01:12 PM   #10
D-nicest's Avatar
All the M3's I've had, have made great runtime(well over 5min) and lots of power. I don't think you should base the engine's performance off the ones you saw, those guys have to be doing something wrong whether it's the clutch setup or tune etc... Pretty much every M3 I've seen over here has been fast. RBM3 combined with a Nova 2652 w/ short header is a great combo.
Diatta Collymore [email protected]([email protected])(www.fordhamhobbies.com) (Wallacemotorsports.net) Fordham Hobbies, Wallace Motorsports, WRC Racing, Hot Race Tyres, Ielasi Tuned Engines, VP Power Master fuel, KO Propo America, Paint By Mikey Mike
D-nicest is offline   Reply With Quote
Old 12-05-2010, 01:16 PM   #11
D-nicest's Avatar
Nova 2652 with short header is the recommended pipe combo. I believe Uriah has a broken in version and a non broken in one if I'm not mistaken...
Old 12-05-2010, 02:33 PM   #12
bluer322's Avatar
Thanks, both seem to be very good.
T. Nicholson
Matrix Tires
Serpent, 748tq
Old 12-07-2010, 04:08 PM   #13
The rb m3 is the fastest .12 on the market period with also making runtime. The rb m3 doesn't lack power anywhere it has tons of low,mid, and topend power and it last forever!!!! My rb m3 was always the fastest .12 on the track. But I am only doing 8 scale for now on it is so much more fun and fastest. Murnan flash .21 I will take (2x) please
HoboShop is offline   Reply With Quote
Which .12 novarossi has it all? JDOM111 Onroad Nitro Engine Zone 27 11-26-2010 11:40 PM
