Old 07-15-2004, 07:40 AM   #1
J_Longbrake's Avatar
Trader Rating: 20 (100%+)
Default Turbo Button for the Mugen X12?
What turbo button do I need to buy for a Mugen X12? Also what shimming is required with the Turbo Button/X12 combo w/ 30% fuel?
J_Longbrake is offline   Reply With Quote
Old 07-15-2004, 08:43 AM   #2
afm
afm's Avatar
Default Re: Turbo Button for the Mugen X12?
Any Nova based engine turbo head button should fit OK.
Shimming with the aluminum .30mm should be oK for 30% nitro
AFM
afm is offline   Reply With Quote
Old 07-15-2004, 09:23 AM   #3
Not true... You'll need a long stroke turbo button for the Mugen x12... A short stroke turbo button that are found on Nova NS3 or Top TS3 won't work... If you can find a RB v12 turbo button, that'll work... Any long stroke .12 based Nova turbo button will work..
RC_Alan
rc_alan is offline   Reply With Quote
Old 07-15-2004, 09:51 AM   #4
afm
afm's Avatar
RC_Alan
Not to create discussion RC_Alan, but you are confusing the old Mugen MT12, which was a long conrod engine that had a thinner head button with the new Mugen X12 which has the same head button as all the new Nova based engines.
By the way all Nova based engines are long stroke engines 14.00 mm vs 13.80 mm bore , and the RRL3 are even longer 14.25mm stroke vs. 13.70 mm bore.
The difference with the old Mugen MT12 was conrod lenght but not actual stroke.
That is why you yourself suggest the RBV12 turbo button, which is the same as the Novarrosi NS3 or TOP TS3 or REX RERS3.
So my suggestion is still valid. Any new based Nova engine tiurbo button will fit, I've done it.
AFM
Old 07-15-2004, 10:29 AM   #5
Exacty what I was looking for guys. A friend of mine ran his X12 with the button and the shim from his TSR12 last sunday and was real pleased with the performance over the standard button. Just wanted to back up what I thought I already knew. Thanks.
Old 07-15-2004, 12:34 PM   #6
chicky03's Avatar
Send a message via AIM to chicky03
So you can use a RB V-12 button on a JP X-12 or not?
chicky03 is offline   Reply With Quote
Old 07-15-2004, 01:51 PM   #7
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Paul: I know you have a Dremel and some aluminum there somewhere.... Make your own.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 07-15-2004, 02:06 PM   #8
chicky03's Avatar
Thanks Scott but I want advice from people who actually know what they are doing!!
Old 07-15-2004, 02:11 PM   #9
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
LMAO!!! Hey Paul, wassup bro? You at the shop? I got somethign to email toya, what's your email at the shop?
BigDogRacing is offline   Reply With Quote
Old 07-15-2004, 02:19 PM   #10
his email is [email protected]
Old 07-15-2004, 03:16 PM   #11
afm
afm's Avatar
YES YOU CAN.
AFM
Old 07-15-2004, 09:30 PM   #12
What up Big Dog. What are you doing sniffing around the nitro area? Holla.
Paul, I will be happy to grind on your motor next time I see you. I have a cordless dremel so I can hook you up at the track.
J Longbrake
Old 07-19-2004, 10:48 AM   #13
chicky03's Avatar
Thanks guys. I tried the RB head and it worked perfectly.
Paul
Old 07-23-2004, 10:53 AM   #14
Send a message via AIM to kreidel
Originally posted by afm
YES YOU CAN.
AFM
Is there any real advantage to using the turbo button on the x12?
kreidel is offline   Reply With Quote
Old 07-23-2004, 12:22 PM   #15
afm
afm's Avatar
About 1,000 more rpm's at top end, and about 0.06 more HP's
according to spec sheets of manufacturers.
Tuning correctly a turbo head engine is more critical, because it is more sensitive to weather conditions.
I would reccomend it for really high end racing, but for club racing or just fun bashing stay with std. head, unless you know how to tune perfectly.
AFM
WTB: NovaRossi/Mugen MT-12 turbo button head. ohmygahitscoby R/C Items: Wanted to Buy 2 12-27-2007 02:07 AM
Turbo 30 5 button WisRacr1 R/C Items: For Sale/Trade 2 03-18-2006 04:53 PM
Need a turbo head button and turbo crank rcfoolz R/C Items: Wanted to Buy 0 07-14-2005 08:52 PM
Mugen X12 Turbo button..? Solara Onroad Nitro Engine Zone 10 05-13-2005 03:46 PM
Turbo 30 9 button, Turbo 35, power supply Greg Amendola R/C Items: Wanted to Buy 0 10-14-2004 11:00 PM
