Rb Ws7-ii
Got a few quick questions could use a hand....
I just bought a WS7-II for my buggy.My LHS owner broke it in on a Hudy bench with 20% Monster HP fuel with an RB #6 plug.Everything was fine.Then I put it in my car, ran for a bit very rich until the plug(very first one, also used for bench breakin) died.Then I started having problems running, to which I eventually determined that well..Im an I.D.I.O.T!!!:blush: ... All jokes aside...I had not used enough oil on my air filter and a lot of dirt got inside the carb.I pulled the carb and head off and cleaned everything up.With the head off and no plug on, I can spin the flywheel freely with no gritty feeling at all, so I don't think any dirt got into the engine.Also, the P/S and the crank are not scarred.Ive put everything back together and plan to try and start it up tomorrow, see how things go...my Q's are 1) What is a basic post break in starting point for the needles. 2) Should I run with or w/o the 8mm carb restrictor. 3) Another employee who runs an S7 suggested I up to 30% as the RB engines are shimmed for this....should I stick with the break in fuel(20%) or up to 30% and if I should go up, which plug? Any suggestions are appreciated...thx :lol: ... and YES, I will clean and re-lube my air filter....with extra oil :blush: |
| All times are GMT -7. It is currently 03:27 AM. |
