Old 06-01-2004, 07:04 PM   #1
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
Default Novarossi NS12 question
I currently running a NS12 5 port engine, i notice there's slight play on my crank shaft, that is ,i can feel a slight movement forward and back, does it mean the enigne might need new bearings ? thanks for the help
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 06-01-2004, 07:10 PM   #2
EdwardN's Avatar
Default Re: Novarossi NS12 question
I am not sure bearing conditions-slightly movement isn't full describe. But in many cases it is normal. Just make sure, when you will install flywheel to pull out shaft all the way out and then slide colet all the way to front bearing, and only after that tigh flywheel. Otherwise, you crancshaft will touch backplate.
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 06-01-2004, 07:17 PM   #3
Tag
Tag's Avatar
i see, thanks for the help...so it's normal with any enigne ?
Old 06-04-2004, 07:14 AM   #4
kt racing's Avatar
Send a message via AIM to kt racing
most engines will have a set amount of play. As long as the crank is hitting the back plate your fine. the thing to worry about is the play up and down not forward to aft.
keith
kt racing is offline   Reply With Quote
Old 06-04-2004, 03:21 PM   #5
EdwardN's Avatar
Most of them, but there is some exotic designs, that play says bearings are gone. But don't vory about them, it is very exotic and hard to find-top end state of the art ( airmodeling, boating and Rc cars).
Old 06-04-2004, 06:20 PM   #6
teammpp's Avatar
Depending on the engine and the car you may also need to shim the flywheel if you are getting excess play on the crank. We put a 0.5mm shim between the front bearing and the collet to take up the play if it is too much.
Try this. Should work.
teammpp is offline   Reply With Quote
Old 06-04-2004, 09:19 PM   #7
Tag
Tag's Avatar
thanks for all the help guys..
|Novarossi NS12 S5| rolly16 Nitro On-Road 5 03-19-2008 01:06 PM
Novarossi NS12-S3 NITRONUTTER Australia For Sale/Trade 4 04-13-2007 11:48 PM
Novarossi NS12 S5 Tag Nitro On-Road 1 12-02-2005 06:42 PM
FS: Novarossi NS12 S3 | NIB David Joor R/C Items: For Sale/Trade 8 07-12-2004 08:26 PM
Novarossi NS12 ME-student Nitro On-Road 54 07-14-2003 12:48 PM
