-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   MT12 problems (https://www.rctech.net/forum/onroad-nitro-engine-zone/40806-mt12-problems.html)
ChvyPwr-BB 05-18-2004 09:20 AM
MT12 problems
can anybody give me a setup on the mt12?
afm 05-18-2004 09:34 AM
Re: MT12 problems
HSN = 5 turns out, then start leaning 1/8th at a time if needed.
LSN = 3 turns out, then lean or open as needed to get at least 30 seconds idle without engine clogin to the point of dying, it should hesitate a little after 30 seconds but not die. To do this, let engine idle then press full throtle for a second or two to clean it out, then check the 30 seconds idle.
Mid Needle = flush with carb body with slot for screwdriver pointing the fuel inlet, then DON'T EVER TOUCH IT AGAIN.
AFM
gonzoY5 05-18-2004 08:59 PM
What characteristics would an overly lean bottom end give? I'm having some setting issues and I could use some help. Thanks
afm 05-19-2004 06:02 AM
Try this tips on tuning engines. Best guide I've seen.
Good Luck
AFM
http://www.teamtrinity.com/tech/nitrotune.asp
http://www.teamtrinity.com/tips/nitro.asp
