MT12 problems
Old 05-18-2004, 09:20 AM
ChvyPwr-BB's Avatar
Default MT12 problems
can anybody give me a setup on the mt12?
ChvyPwr-BB is offline
Old 05-18-2004, 09:34 AM
afm
afm's Avatar
Default Re: MT12 problems
HSN = 5 turns out, then start leaning 1/8th at a time if needed.
LSN = 3 turns out, then lean or open as needed to get at least 30 seconds idle without engine clogin to the point of dying, it should hesitate a little after 30 seconds but not die. To do this, let engine idle then press full throtle for a second or two to clean it out, then check the 30 seconds idle.
Mid Needle = flush with carb body with slot for screwdriver pointing the fuel inlet, then DON'T EVER TOUCH IT AGAIN.
AFM
afm is offline
Old 05-18-2004, 08:59 PM
gonzoY5's Avatar
What characteristics would an overly lean bottom end give? I'm having some setting issues and I could use some help. Thanks
gonzoY5 is offline
Old 05-19-2004, 06:02 AM
afm
afm's Avatar
Try this tips on tuning engines. Best guide I've seen.
Good Luck
AFM
http://www.teamtrinity.com/tech/nitrotune.asp
http://www.teamtrinity.com/tips/nitro.asp
afm is offline
