Old 05-17-2010, 10:34 AM   #1
Default Capricorn Lab E01 .12 Engine
Hello from France,
here's the beginning of the presentation of this new engine.
So capricorn produce a nice car, what about the engine???
romuald31 is offline   Reply With Quote
Old 05-18-2010, 07:12 AM   #2
Here are some news for the E01 engine.
New Majored Underhead.
Increase by 30% the heat dissipation.
New combuster chamber design for a higher RPM and lower fuel usage.
Available shortly for our engine and of course for all the Novarossi Flash Based engine line.
Capricorn Lab E01 .12 Engine-lab-e01.jpg   Capricorn Lab E01 .12 Engine-new-head.jpg
CapricornRC is offline   Reply With Quote
Old 05-18-2010, 07:14 AM   #3
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
11.9mm? or 11.5mm?
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 05-18-2010, 07:24 AM   #4
Originally Posted by Riketsu View Post
11.9mm? or 11.5mm?
11.5
Old 05-18-2010, 11:27 AM   #5
Team Kamikaze's Avatar
Originally Posted by CapricornRC View Post
11.5
What does "albero D11.9" on the analyzed timing chart mean?
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 05-18-2010, 11:51 AM   #6
nitrodude's Avatar
Albero means tree. I think it means that crankshaft is 11.9, not 11.5.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 05-18-2010, 12:02 PM   #7
Sorry
Wrong editing
Is 11.5
Old 06-16-2010, 05:56 AM   #8
Is this engine based off of the Flash 12 and can someone tell me how it compares ?
THanks
jelayne is offline   Reply With Quote
Old 06-16-2010, 06:08 AM   #9
musti72's Avatar
its based on novarossi plus 12-3SCT
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 06-16-2010, 06:58 PM   #10
Thanks musti72
Do you all know how it compares to the Flash12 in performance??
Old 07-01-2010, 12:22 PM   #11
Has anyone run this motor yet? Thoughts?
bradley70 is offline   Reply With Quote
Old 07-01-2010, 12:35 PM   #12
musti72's Avatar
Originally Posted by jelayne View Post
Thanks musti72
I havent got one yet, but my next engine will be either Sirio XXXV or new version of the Capricorn engine:
http://www.redrc.net/2010/06/caprico...-bc-12-engine/
Mustafa Alp
Old 07-19-2010, 04:39 PM   #13
DS Motorsport's Avatar
Default Capricorn LAB E01-BC
Last friday I received my LAB E01 BC engine together with the 2662 exhaust and the 2010 WCE NT1 clutch set.
This weekend we had our nationals at my home track and I can only say the power this engine has is incredible.
There was only one engine with a higher top end speed and that was the factory Gimar engine of Maxim Claes, but the Capricorn engine had clearly more bottom end and mid power.
This is in a field with pretty much every brand of highly tuned engines.
The internals look very nice, especially the crankshaft. Another plus was how easy the engine starts when it is already hot, this is due to the insulated carburetor.
The engine comes with the best description how to break in an engine I have seen thus far, very detailed.
Only had two small issues with the engine, first the carb securing bolt came undone and the carb moved a bit out of the crankcase causing a very high idle during final. Another one was the backplate bolts hitting the monoblock engine mount of my NT1. The engine comes with some nice hex hardware for the engine but the heads of the backplate bolts are a bit too high, replaced the normal bolts and everything was ok.
Ow, and on saturday I broke a rear driveshaft under full acceleration, simply snapped at the CVD side.
Also really liked the Capricorn clutch, it just gives the car a far better acceleration. It's really easy to set it up perfectly to get that clear high pitch sound you want when the clutch engages.
The spring preload advised in the manuel (0.3-0.4) was a bit too much in my case, had to go back to 0.15 preload to get a proper engagement. But after this the clutch has been perfect all weekend.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 07-21-2010, 04:40 PM   #14
hey ds what do u have your clutch gap set at
Capricorn LAB C-01 / RBtj 10 / Spectrum DX3
Roadrash730 is offline   Reply With Quote
Old 07-21-2010, 04:58 PM   #15
Clutch gap of 0.42 set like described in the manual with 0.1 endplay.
Clutch was very good like this.
P1-RC.com
