Like Tree1Likes
JP engines
Old 03-05-2013, 12:54 PM
  #1126
Roelof's Avatar
It raises the timings of the intake and exhaust ports so yes, more performance. Capricorn does sell these ready to fit shims.
Roelof is offline
Old 03-05-2013, 02:04 PM
  #1127
Obviously the gasket has to be thinner from stock by the amount you are increasing underneath the sleeve right?
Does it take a lot from the bottom end?
speed6 is offline
Old 03-05-2013, 02:24 PM
  #1128
Roelof's Avatar
Yes, you have to keep the button head on the same height so you must take away the same amount of headshims.
No, you will not loose bottom power that much (maybe even not noticeable), one shim of 0.1 or 0.2mm can make a difference in feeling in the top range. It is easy to give it a try and to go back.
Roelof is offline
Old 03-05-2013, 06:43 PM
  #1129
SOLOARTIST 702's Avatar
i think i should get a couple for my jp's
SOLOARTIST 702 is offline
Old 03-06-2013, 02:25 AM
  #1130
the fuel consumption may a bit higher
kyosho malaysia is offline
Old 03-06-2013, 09:09 AM
  #1131
More run time you mean?
Everyone mentioned Pro's what about the Con's of altering this type of timing?
speed6 is offline
Old 03-06-2013, 09:26 AM
  #1132
Roelof's Avatar
More consuming....
Roelof is offline
Old 03-06-2013, 10:21 AM
  #1133
More consuming....
Old 03-07-2013, 12:34 AM
  #1134
[QUOTE=Roelof;11894789]Yes, you have to keep the button head on the same height so you must take away the same amount of headshims.QUOTE]
I am not agree with that. I dont know why you have to take off the same amount of headshims. Please, could you explain it to me?
ngracing is offline
Old 03-07-2013, 01:15 AM
  #1135
[QUOTE=ngracing;11901283]
if you won't than the combustion chamber will get bigger which will result in less combustion power. Keep in mind that piston isnt going any higher its just the sleeve so you need to compensate.
speed6 is offline
Old 03-07-2013, 02:11 AM
  #1136
Roelof's Avatar
You will raise the sleeve and with that also the button head while (as mentioned) the piston does not change in height. The offset on the sleeve has to be corrected on the button head by taking away the same amount of shims.
Roelof is offline
Old 03-07-2013, 04:56 AM
  #1137
Ok, now I understand everything. I will test it, we are talking about 0,1 or 0,2 mm, right?
ngracing is offline
Old 03-07-2013, 07:50 AM
  #1138
you will love it
Old 03-09-2013, 04:56 AM
  #1139
how can I measure the combustion chamber? I have to put the piston in the highest position, but the piston is not smooth. Which is the right point to do it?
ngracing is offline
Old 03-09-2013, 07:15 AM
  #1140
since were on my favorite subject who knows the difference between the R9s and jp 35 more torque or more rpm
