JP engines
#977
Tommy
#980
Hey guys, for an FX21, what is considered decent pinch?
Mine accidently had the filter come off but unsure how much is ran. I want to say it wore it out a good amount, but want to confirm with you folks.
#981
Take the motor apart,clean it up,lube and rebuild. with the flywheel mounted, plug installed,and backplate on, turn the crank by hand. You should get a good amount of resistance turning a full revolution. If you hear that "puk" sound,chances are its still good to go.
#982
Place a few drops of after run oil trough the top (removing plug), then place plug in place, then roll piston to top dead center and listen and look for air bubbles through exhaust port. If there’s none, then your engine still has compression, even if it has no pinch.
AFM
#983
Thanks guys!!!
#984
What glow plug does the JP-12 P3-L 'Black' edition take?
I am interested in one and want to order a few glow plugs with it. I know that i want turbo cold plugs but don't know which type (long short).
It will be used with 16% nitro.
Preferably novarossi glow plug numbers. Thank you guys
#985
Part# 68865 TURBO GLOWPLUG / GOLD #6 HOT
Part# 68866 TURBO GLOWPLUG / GOLD #6 COLD
Usually, we use the cold version.
#986
Question about plugs: do the Lrp #7 plugs fit the jp engines?
#988
#990
Try www.absolutehobbyz.com
Direct
FX21R09 $698
FX21R09S $531
Contact us if you have any questions, [email protected]
Direct
FX21R09 $698
FX21R09S $531
