Old 02-20-2009, 07:49 AM   #901
DS Motorsport's Avatar
Originally Posted by staikosn1 View Post
I think im gonna go with RB RC!!
It's a fast engine for a reasonable price
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 02-20-2009, 11:01 PM   #902
Big Midget's Avatar
Trader Rating: 100 (100%+)
hey guys does anyone know if this is a good engine JP FXTO3 .12
Thanks for your time.
UltralineHobbies.com
Ultraline Raceway Topeka Ks
Dee & Mee Hobbies RickyRacer Lidz,Absolute Tattoo,Fuzzy Dice Decals
Big Midget is offline   Reply With Quote
Old 02-21-2009, 11:49 AM   #903
Yes the jp fx.12 t03t is a very hard engine to find due to the fact that it is outy of production but it is still one of the fastest .12 on the market it is not that much slower than the eagle tl3t .12 crazy topend. I would snatch it up right away get buy.
HoboShop is offline   Reply With Quote
Old 02-21-2009, 12:08 PM   #904
Big Midget's Avatar
Thats very good to hear!! What if I need parts for it since its out of production......
Its a used engine on a mtx4 I bought. Supposedly it was raced at the IFMAR Worlds in 2006. I'm under the impretion its been well cared for.
Do I have a chance of rebuilding it if needed?
Old 02-21-2009, 12:16 PM   #905
Team Kamikaze's Avatar
P/S/Rod sets are still available.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 02-21-2009, 12:27 PM   #906
Big Midget's Avatar
Thanks I just checked on them. I'm looking at a little under $200.00 for the piston and sleave when needed. Does that sound right....
Are the other parts available then??
Old 02-27-2009, 08:41 AM   #907
staikosn1's Avatar
Send a message via MSN to staikosn1
The JP P3L black how can be compared with the RB R3??
XRAY NT1 || RB T10 RC || FUTABA BLS || SANWA M11 ||
#FANATIX MODELS# #www.frt.gr#
staikosn1 is offline   Reply With Quote
Old 02-28-2009, 01:43 PM   #908
the rb r3 has more bottomend and midrange but the jp has a tick more topend and it gets better gas mileage but for the price i would go with the jp firstline p3l great buy but the rb r3 is the better engine but hard to get parts for now that rb usa is no more.
Old 03-09-2009, 01:54 AM   #909
Trader Rating: 27 (100%+)
Hi guys. I am very glad there is a thread and so many knowledgable folks on this engine
Anyway. I have a used FX-21 5N off-road engine. It still has great pinch and does not seem to leak anywhere. I was chasing a tune today but when I got home I saw that my needle settings were way off the factory, so I am not too worried.
I wanted to ask, what is a good plug for these? It currently has a nova 7. Also, how many shims should it have? I took apart the top and saw that it had absolutely no shims... I checked the JP site and saw it has several listed.. How many/thickness should I be running with 20% (byron) fuel? Could lack of shims be why I was chasing tune? Do I need specific JP/Nova shims or could others work as long as thickness is same?
Also, I attached a picture, does it look like its been running lean or does that look about right? Yeah, newbie question...
Thank you!
spawn_x is offline   Reply With Quote
Old 03-09-2009, 06:54 AM   #910
Trader Rating: 4 (83%+)
Your head shims should be 0.70 for 20% byrons,take a digital caliper and measure all shims together and thats what you should have, as far as the plug i found the best results with the Nova #5 hot and OS P3 ..
Roniel_R is offline   Reply With Quote
Old 03-09-2009, 07:30 AM   #911
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default jp fx r03
Any one know what novarossi motor the fx r03 shares parts with especially case and crank?
Jamie
J.Gonzalez is offline   Reply With Quote
Old 03-09-2009, 08:38 AM   #912
aturbotony's Avatar
Jamie
novarossi 321P
Tony Thompson / Mugen Seiki USA / RC America / Airtronics / Flashpoint Fuel / Novarossi USA /Jgo paints / DeSoto Racing/ Murnan Modified Motors / Zac Project Tires / My Wife and Kids /
aturbotony is offline   Reply With Quote
Old 03-09-2009, 09:22 AM   #913
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Thank you!
The pic looks a bit lean, or at least a bit dry. It should still have a little oil, but you can see whats in the pics. Make sure your shims aren't stuck to the button. It should have two 0.30mm aluminum shims and one 0.10mm copper=0.70mm total spacing. I would recommend 25-30% fuel, which should work fine with the shimming I stated on a broken in engine. Base carb setting new is around 5 turns out LSN & 3 turns out HSN. Broken in, around 2.5 HSN out and 2-3/4 to 3-1/4 out LSN. This setting should, but you still have to tune it. Glow plugs used are #6 or even a #5 if its humid and hot and you need to richen the LSN more and have a good idle.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 03-09-2009, 05:24 PM   #914
Its dry because I wiped it, but yes I thought it was running lean too
To my surprise, no, it did not have any shims. They are not stuck anywhere, they are just not there, old owned probably took them out for some reason. Does the increased compression actually give it more power or just mess with things?
Old 03-09-2009, 07:08 PM   #915
ezveedub's Avatar
Thats very odd. If I'm not mistaken, no shims will most likely make the piston touch the button. You need shims. It will be very hard to tune your engine with a squish band that close. Take a look at the head button and see it it has dimple marks on top, like ... or .:. or if it has an actual part number on it. If so, what is it? For some reason, the shoulder on the button looks like a 0.30mm aluminum shim is there in your picture.
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
