Building 1 engine from several brands parts
I just got a box with all my old (broken) engine stuff, it was all examened by my sponsor in the use for devellopment/comparing their engine.If I could build up something for trainig, spare or as a rain engine.
I found the case of my old RB Xenon-R (Sirio based), I know it has runned just 6 or 7 liters before the rod broke. The crankpin was still OK end in good size and no play on the bearings so this must be a good start. http://www.euronet.nl/users/tooms/ftp/evo5/motor1.jpg A good looking sleeve of a JP R01 and a fitting piston with a R7 rod must make a fit. http://www.euronet.nl/users/tooms/ftp/evo5/motor2.jpg RB dos have some differences comparing standard Nova based engines and one of them is the location pin. A small cut on the opposite side is simple to do. http://www.euronet.nl/users/tooms/ftp/evo5/motor3.jpg The hole in the case for the sleeve is 19.4mm while the JP sleeve is 19.5mm, I fixed an adapter to mount the sleeve in my drill station and with a piece of sandpaper I could grind it down to 19.4mm When fitted it was clear the sleeve was sitting to low so from a 0.5mm thick plate aluminium I made a ring for under the sleeve which did set the sleeve almost to the right height looking through the exhaust. http://www.euronet.nl/users/tooms/ftp/evo5/motor4.jpg RB has a crankpin of 5.02mm so a R7 rod with a 5mm hole will not fit. I have a dremel 5mm diamond grinding bit I have used before to do this job. Now it fits like a glove. http://www.euronet.nl/users/tooms/ftp/evo5/motor5.jpg In the box also some heads made by my sponsor to fit Novarossi engines. It has an in one piece combustion chamber for a maximum cooling. It did not work that good because the chamber was to small and to much head clearance needed to be used. With a 10mm drill I could make it a tiny bit wider and straighter in shape to get more volume. http://www.euronet.nl/users/tooms/ftp/evo5/motor6.jpg While I was busy I just drilled some holes to make it lighter, I did go from 70 gram to 65 gram, not that much and I think most racers do not notice that. http://www.euronet.nl/users/tooms/ftp/evo5/motor7.jpg With a piece of solder setted the head clearance to 0.7mm to start with and mounted it all togeather. http://www.euronet.nl/users/tooms/ftp/evo5/motor8.jpg OK, the stroke of the crankshaft does not fit the stroke the P/S set needs but 0.1mm difference (16.7 / 16.8) is not a huge difference Now just to mount a clutch and give it a try. |
Awesome!
Let me know how it turns out.I like these experiments. |
Do not get this the wrong way, but I would be very surprised if this engine would make good power and run consitantly.
But, you never know.;) Let us know how it went.
Originally Posted by Roelof
(Post 7237981)
Originally Posted by stefan
(Post 7240761)
But, you never know.;) Let us know how it went. Maybe next weekend I will give it a try, I will mount a clutch and can make a start in the backyard. You will hear more! |
interesting...
Roe's the man, that custom made mrx4x front belt tensioner u sent me last year worked flawless all season...he knows his stuff, id be suprised if it DIDNT run good...lol...
No more stripping belts? :lol:
Yes, that is an easy solution for the frontbelt which should we a standard in the kit, I am glad you like it. In the current days it is a shame that most people can not (or will not) fix problems by creating solutions than only getting option parts. Back in the days that was different, a lot of parts needed to be modified or home made. This is just a funproject to see if it can be done and so far with simple tooling it is possible. I am sure the engine will run and regarding the current height of the ports I think it will run OK. These are just old parts, there is no investment and so nothing to loose but if it works I could arrange a new P/S set. |
hey roe, just curious, how did it work out? and how do u like the looks of the new mrx coming out?
tommy |
It did run fine for a short time, the piston did become very loose. In the beginning the piston did feel great but the sleeve was probebly from a broken engine and a tiny bit misformed that the piston did push back in shape.
The 1st impression was OK. I have pinched it and need to run it in but did not have the time due races and work. |
| All times are GMT -7. It is currently 11:31 AM. |
