How to pull out a flywheel ?
I need help on how to pull out a flywheel without hurting the shaft or the engine.
There might be many ways to do it and what is the best way?
Thanks,
N
Thanks,
N
Re: How to pull out a flywheel ?
Thanks,
N
Thanks,
N
a cheaper alternative is a gear puller.. its available at hardware stores. just remember to put back the screw of the sg crank (if it is sg) so that the crank wont get damaged. hope this helps.
Thank you for the information. where shall I get an automitive battery terminal puller?
hammer? give me a break I dont even have that strength to manage a hammer and what kind of rubber hammer you are talking about?
Cheers,
N
Cheers,
N
just a regualt rubber mallet
This one was 3 something on the website I found the picture on.
oh, a rubber hammer. I have seen this somewhere. but but but, how do you use this to pull out the flywheel? it is quite different to those posted earlier on this forum.
turn the engine over, so that the backplate/pullstart is facing you.
and slowly (AND LIGHTLY) tap around the flywheel. Keep going around the flywheel tapping lightly and it will come off.
thank you, I always get fast reply here. I love this forum.
