-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   How to pull out a flywheel ? (https://www.rctech.net/forum/onroad-nitro-engine-zone/38138-how-pull-out-flywheel.html)
NetBike 04-12-2004 11:02 PM
I need help on how to pull out a flywheel without hurting the shaft or the engine.
There might be many ways to do it and what is the best way?
Thanks,
N
KMW 04-13-2004 02:12 AM
Re: How to pull out a flywheel ?
Thanks,
N
http://microrcshop.com/Merchant2/mer.../to_wr/SRP-002
sup 04-13-2004 03:12 AM
a cheaper alternative is a gear puller.. its available at hardware stores. just remember to put back the screw of the sg crank (if it is sg) so that the crank wont get damaged. hope this helps. :D
corvettecrazy 04-13-2004 08:59 AM
http://www.rccaraction.com/rc/articles/toughtask.asp
NetBike 04-14-2004 03:13 AM
Thank you for the information. where shall I get an automitive battery terminal puller?
1fastdude 04-14-2004 07:34 AM
Just tap it with a rubber hammer!!!! Jeesh:nod:
J_Longbrake 04-14-2004 08:56 AM
Eli is my hero! :D
NetBike 04-14-2004 11:28 PM
hammer? give me a break I dont even have that strength to manage a hammer and what kind of rubber hammer you are talking about?
Cheers,
N
1fastdude 04-15-2004 05:21 AM
If u have to ask.... then u probably don't understand!!!!:cry:
corvettecrazy 04-15-2004 12:26 PM
just a regualt rubber mallet
http://bargainbuff.nstemp.com/cgi-bi...tes/mallet.jpg
This one was 3 something on the website I found the picture on.
NetBike 04-15-2004 06:11 PM
oh, a rubber hammer. I have seen this somewhere. but but but, how do you use this to pull out the flywheel? it is quite different to those posted earlier on this forum.
corvettecrazy 04-15-2004 07:34 PM
turn the engine over, so that the backplate/pullstart is facing you.
and slowly (AND LIGHTLY) tap around the flywheel. Keep going around the flywheel tapping lightly and it will come off.
NetBike 04-15-2004 08:02 PM
thank you, I always get fast reply here. I love this forum.
TSR6 04-17-2004 11:17 AM
I know you do... You have a PM. :)
nitrodude 04-17-2004 12:33 PM
It will be easier if you first put the engine in an oven at 350 degrees for 30 minutes. Then tap it with the rubber malet.
