-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   after run (https://www.rctech.net/forum/onroad-nitro-engine-zone/378916-after-run.html)
bugers 03-11-2010 09:12 AM
after run
hi there, i was just wondering what is the ACTUAL way of after running your engine, i just want to know becouse there is so many different people telling me ways in how to do it and i dont know which is good way
Team Kamikaze 03-11-2010 11:03 AM
It is always a good idea to use some after run oil. To use after run oil, let the tank run completely empty at idle until it runs out of fuel (try re-starting the engine several times with the glow igniter installed). Next put a few drops of after-run oil down the carb (hold it open) and a few drops down the glow plug hole. Leave the plug out and put a rag over the top of the engine. Spin the engine over for five seconds on the starter box. Put a few more drops down the carb, re-install the glow pug and spin the engine over five more seconds. You’re done!
offroad racer 03-12-2010 02:57 PM
I use 2 stroke motor oil. Its cheap, you get a lot, and it works better.:cool:
helivaguy 03-12-2010 06:16 PM
dont forget to set piston at the bottom.
lil-bump 03-13-2010 06:25 AM
I used marvel mystery oil. I also try to clean the Glow plug area before I remove the plug. You don't wont debree falling into the engine when you removed the glow plug. I blow the glow plug area with compressed air while the car is held upside down then I remove the glow plug.
Pass you soon...
bugers 03-13-2010 06:43 AM
does anyone know if there is any guides on HOW to after run your engine. thanks
lil-bump 03-13-2010 07:48 AM
I think we all just explained it?????
P2gee 03-13-2010 09:21 AM
I use a slightly different procedure and oil product and both have served me well for several years. For oil, I use Blaster 404 Air Tool Oil & Conditioner. It comes in a 12oz spray can and features a pinpoint spay nozzle for spraying into tiny air fittings. Any auto parts store that sells PB Blaster products should be able to get this for you. My procedure tries to emulate the NR recommended solvent flush with out tearing the engine apart. It is also intended to flush all the nitric acid out of the engine after a run.
1. Empty fuel tank and run excess fuel out of engine.
2. Remove glow plug and air filter.
3. While spinning engine on starter box, spray a continuous stream of 404 into WOT of carb until oil starts purging out the glow plug hole (5-10 seconds). Stop.
4. Place rag over glow plug hole and spin engine again to pump excess oil out of engine.
5. Replace air filter and glow plug, ready till next race.
Next time you start the engine it will be a bit cantankerous about running as the 404 does not combust very well. Just be patient and nurse the throttle until the 404 runs out. Hope this helps.
