Sirio evo 4 & Orion Alpha .12engine
Hi guys, I need more information about this 2 engines therefore hope that u all can help me!
From what i know the new .12 Orion Alpha is a sirio based engine and i know that both Sirio evo 4 n Orion Alpha share the same engine bearing size.. So i would like to know do they share the same p/s, rod and crank? Thanks :sweat: |
The Orion Alpha .12 are based on or actually are Sirio XXX engines.
The Evo 4 had a different bore and stroke...and the well known sleeve layout. The XXX engines have a much shorter liner where the TDC is the top of the sleeve. So both...p/s sets and combustion chamber are different between both engines. Same for the crankshaft... Conrod and bearings are interchangeable... --- MARTIN --- |
Originally Posted by Maddin21
(Post 7101553)
Originally Posted by NitroWD
(Post 7103777)
can i fit a orion alpha PS set into a sirio STI4?
Originally Posted by stefan
(Post 7105607)
Did you actually read what he posted?
sorry i'm not too versed in engines. ;) |
