-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   Sirio 12 engine conrod question (https://www.rctech.net/forum/onroad-nitro-engine-zone/37636-sirio-12-engine-conrod-question.html)
jasoncsc 04-06-2004 11:27 PM
Hello,
I disassembled my Sirio 12 engine to replace piston/liner. However, I forget to note down the orientation of the conrod. I notice that the conrod, on the end that is to go to the crankshaft, have one side with a small oil hole with a long groove, and another side with just a short groove and no hole. Should the "hole side" face the conrod, or it should face the backplate?
Manticore 04-07-2004 12:25 AM
Re: Sirio 12 engine conrod question
Originally posted by jasoncsc
Hello,
the small oil hole should be facing the front of the engine.
bbntc3 04-07-2004 04:58 PM
I've always concidered the flywheel end of engine as the rear, so the oil hole in rod goes towards the flywheel end and when piston is at TDC the skirt on piston should have the exhaust port closed.
Manticore 04-07-2004 05:53 PM
is that true you call your back plate as front plate? :confused: :confused:
bbntc3 04-07-2004 07:50 PM
Front plate back plate?? WTF?? I just thought you were kinda confusing, especially to a begineer. I see so called backing plates used on all type of engines and they are not facing the back of the engine, but.. still called backing plates. Call it what ever you want, most people consider the flywheel end of an engine as usually the rear of an engine. :nod: :nod: :lol: :lol:
bbntc3 04-07-2004 07:54 PM
delete
Manticore 04-07-2004 08:42 PM
if you think i am making confusing statement to "NEWBIE", i rephase my suggestion here.
"the small oil hole should be facing the crankshaft"
so, newbie should be able to understand that no matter he calls it front plate or back plate ?.
kt racing 04-08-2004 05:37 AM
oil hole always faces the crank shaft. If not it will lock the rod on the crank pin.
bbntc3 04-08-2004 01:40 PM
I never called it front plate you just suggested I did. Just remember newbie everything is backwards in HK. LOL
mckrooz 04-08-2004 03:29 PM
Or rear exhaust as front exhaust:p :weird:
PUNISHER 04-08-2004 07:55 PM
:lol: :ha: :lol:
You are so confusing the "NEWBIE"!!
OR
"the small oil hole should be facing the Carburetor"
;) :nod: ;)
sparksy 04-10-2004 08:56 AM
Is it just me or are people getting dumber?
bbntc3 04-11-2004 08:10 AM
I build in the neighborhood of 100 gas and diesel engines a year , and have done this for over 30 years.Some are over 2000 HP. The rear end of all engines I build in the most cases is the flywheel end. All though there is a few exceptions to the rule.
Thanks Manticore for clearing it up for the newbie.
Sparksy : It's just you!!!! You know where you can take the rear of your engine and stick it ??
