opinion on nova ll3
opinion on nova ll3
i got this motor from a great guy off this web site and im having trouble getting a tune just when i think its good it turns to crap the front bearing is leaking a little could that be causing all the problems its like it goes lean no matter how much i ritchen it up ive actually had the lsn screwed 5 turns out and it still acted lean the factory setting is 2.5 turns out ????
Please any help would be apperciated
Sounds like a air leak. Check all the seals and make sure the carb is seated all the way in the block. If those are good then its probably the front bearing leaking.
Sure we can take a look. You can order ceramic bearing from Boca for cheap. Walter at the track has the tool to put it in for ya. I think its bocabearing .com.
Just order a new one. I think there around 20 each.
You get what you pay...
I think TKO is the way to go!!
problem resolved money refunded and motor returned thanks for the input but what i would have cost to fix it was well more that the actual cost. as i got into the motor there was more probs than i thought just an honest mistake so thanks to NOT dealing with a scammer it was resolved with no problems
