Old 01-07-2010, 12:07 AM   #16
Roelof's Avatar
Send a message via ICQ to Roelof
Originally Posted by staikosn1 View Post
So we trust that little engine or we stick with the evo3's if we want a picco ??
Good question... If you do need a new rod you never know what you get.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 01-07-2010, 05:45 AM   #17
staikosn1's Avatar
Send a message via MSN to staikosn1
I thought to own one of those but seems too expensive!!
XRAY NT1 || RB T10 RC || FUTABA BLS || SANWA M11 ||
#FANATIX MODELS# #www.frt.gr#
staikosn1 is offline   Reply With Quote
Old 01-07-2010, 09:14 AM   #18
Through the years the quality of Picco has it ups and downs.
My 1st Picco (based) engine was the Mega P5, A good engine but sadly a very bad carburator.
After some bad things with Novarossi I decided to get a Picco, a G1-Pro. A very good and fast engine but the rod broke in the 1st race after running in. Did place a new P/S set and the sleeve broke in 2 halfs. After a deny of the distrinuter yo arrange some warranty I decided not to buy a Picco annymore.
But a few years ago the sponsor wanted to see one and bought a Mega ZX21, after running in all compression and power was gone....
I know Novarossi also has it ups and downs but not as bad with Picco's.
I think you've made the most informative post about engines that I have ever seen here and I see it at the track every week.
Nova fails, they go Max, Max fails they go Sirio, Sirio fails they go Picco, Picco fails they go back to Nova and the cycle starts over and the racer is unhappy and believes the engine is fully at fault (and sometimes is) but each manufacturer has released a new 100% better engine by the time they get back to them.
The evo4 is an improvement on the evo3 for durability, the rod lasts twice as long in my experience and I haven't broken one yet but you can actually feel when it's getting loose unlike the evo3 but I changed rods every gallon "just to be sure" but at a cost of around $20 retail on the 3, is it that expensive? I know some of you run engines for 30 gallons, I don't.
One thing I haven't kept track of in my years of racing until recently was the fuel we use, every one of us has a local fuel guy that mixes some great stuff. Then you have the production fuels like Byrons and Nitrotane among others. I have seen problems with the home stuff and the production stuff depending on the batch and chinas supply of nitro. Just recently I had a case of Byrons 25%/12% oil and I had to add a cap or two of oil to get the proper burn that left the top of the piston with a slightly wet look and the crank wet after running. I burned a piston/sleeve assuming that the 12% oil label on the bottle was correct and ran too much before consulting an expert when my power dropped off on my .21. We popped the head and sure enough, there was not enough oil which caused excessive wear. Take a sharpie and try to mark the rod right after you run, if it writes easily then you don't have enough oil and 9 times out of 10 the engines I have seen lately fail have all had a lack of oil where something seizes causing the rod to break.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 01-08-2010, 07:17 AM   #19
tcmodels's Avatar
Looks good
www.tcmodels.net - online hobby shop
tcmodels is offline   Reply With Quote
Old 01-24-2010, 11:49 PM   #20
YR4Dude's Avatar
Trader Rating: 44 (100%+)
I've had three gallons on a JL3. Changed the rod religiously just before the end of the gallon everytime. Still runs great and still has plenty of compression. I run it with Maxy's 30%
I recently replaced it with an Evo4.
BTW, that P1 motor doesn't exist at Kamikaze. I know because I bought the Evo4 from there. Its the best Picco they have
YR4Dude is offline   Reply With Quote
Old 07-26-2010, 02:07 AM   #21
Where can I buy it?
B.S. is offline   Reply With Quote
Old 08-13-2010, 06:21 AM   #22
Now in stock
http://www.rc-mushroom.com/product_i...ducts_id=19655
Old 09-04-2010, 03:54 PM   #23
which pipe would you prefer for this engine?
SebO is offline   Reply With Quote
Old 09-04-2010, 08:07 PM   #24
NitroWD's Avatar
2651...no doubt.
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 09-05-2010, 01:06 PM   #25
Send a message via Skype™ to carletto
Originally Posted by NitroWD View Post
2651...no doubt.
http://www.wpengines.com/components/...6e5d4600ee.jpg
same low end....more top end
www.wpengines.com
carletto is offline   Reply With Quote
Old 09-05-2010, 01:18 PM   #26
http://www.wpengines.com/index.php?o...ri12&Itemid=11
our jewel with ceramic bearing
Old 09-06-2010, 09:52 AM   #27
Anybody tried this engine (or EDO mod) or see it in action?
Old 09-07-2010, 08:22 AM   #28
gfilos's Avatar
i have seen it in action and it looked very good, both low and top-end. It was a picco evo4 edo modified.
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 09-08-2010, 01:48 AM   #29
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
ran the .12 evo4 non mod this season. with the 2651 pipe i got 6 minutes runtime safely. for me, the engine ran best with a lean bottom end and a neutral top.
engine ran great from 200-230 F. drag raced an os tz spec2 - seemed on par.
i guess not many people have good luck with these engines... I've enjoyed mine a lot.
cant wait for the next picco
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
