Old 02-27-2004, 09:37 AM   #1
Default Bench running in
Hi i wish to try running an engine in on the bench using propellor, what size prop would you use.
thanks lemtech
lemtech is offline   Reply With Quote
Old 02-27-2004, 10:20 AM   #2
afm
afm's Avatar
Default Re: Bench running in
thanks lemtech
My Serpent run-in bench came with a 240 - 17 propellor.
AFM
afm is offline   Reply With Quote
Old 02-27-2004, 10:29 AM   #3
rod_b's Avatar
Send a message via AIM to rod_b
afm - how much did that cost you and where did you get it from? I've been thinking about getting one
rod_b is offline   Reply With Quote
Old 02-27-2004, 10:56 AM   #4
afm
afm's Avatar
Part N 3400 Serpent Run-In Bench. Can't remember exactly, I bought it about 2 years ago.
Try www.atomichobbies.com Speak to Phill or Anthony (owners)
Great service and prices.
AFM
Old 02-27-2004, 11:52 AM   #5
stefan's Avatar
Send a message via AIM to stefan
I was thinking about building a bench, using an old chassis and tank.
I guess I'd have to get the prop adapter from Serpent, bit it should cost a fraction of Serpents bench which goes for close to $200.
stefan is offline   Reply With Quote
Old 02-27-2004, 02:43 PM   #6
what sort of routine do you use to run the engine in.
Old 02-27-2004, 03:01 PM   #7
afm
afm's Avatar
This a quote from Serpent's manual.
"Running in the engine on a run-in bench
Using the Serpent Run-In Bench (#3400) makes it a lot quicker and easier to run-in the engine. Richen the main needle by turn, and run the engine for 10 minutes at low RPM. Then run the engine for an additional 15 minutes at medium-high RPM at the same richness setting.
Install the engine in your car, and run the car through 3 more tanks of fuel while adjusting the carburetor to achieve a good top-speed."
I would add: Let the engine cool off completely between tanks, and the first tank do it heat cycling every 2 minutes.
AFM
Old 02-27-2004, 03:06 PM   #8
thanks
trying to clean up the RC bench Mattyfats420 R/C Items: For Sale/Trade 73 05-29-2009 01:11 PM
BREAK IN BENCH COOLEY R/C Items: Wanted to Buy 3 03-28-2008 01:13 PM
running too rich or running to lean bumm_off_street Nitro On-Road 7 03-29-2006 08:28 PM
Bench Racing (2) tmail55 Florida Racing 2 12-04-2005 10:53 AM
Bench Racing tmail55 Electric Off-Road 0 11-28-2005 10:03 PM
