Old 11-20-2009, 12:35 AM   #16
Roelof's Avatar
Send a message via ICQ to Roelof
Also take a look to the OS plugs, they are working very good!
If the Max plug is the same as the GRP is not to tell, the body is indeed the same but thet does not tell about the wire. But there must be a reason Max is shifting to another glowplug.....
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 11-20-2009, 12:38 AM   #17
Trader Rating: 27 (100%+)
Guys, I have a standard rossi plug, #7, its for my JP FX-21 B5N. What McCoy could I substitute it with? An MC-8 work ok? Or I should stay away from those for this engine?
spawn_x is offline   Reply With Quote
Old 11-20-2009, 01:06 AM   #18
wingracer's Avatar
Trader Rating: 24 (100%+)
For standard plug motors, MC8 and MC9 are great.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 11-20-2009, 01:07 AM   #19
wingracer's Avatar
I've always been leery of that because the opposite, a Nova plug in an OS, leaks like crazy. But for whatever reason it seems to work OK.
Team Shepherd USA
Old 11-20-2009, 02:58 AM   #20
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Originally Posted by fulcrum2 View Post
+1 on wingracers post. At the time being Novarossi plugs dont work. They just dont glow any more after a short time despite the fact that the filament will still look like new...
I do notice this after a while - rather strange but from using RP6 on my OS .12 engine these plugs just kept on going and going and going!
So can someone answer the question will the OS RP7 glow plug work on the Nova? Will there be plenty of clearance etc - anything i need to look out for?
Cheers
Frankie
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 11-25-2009, 06:57 AM   #21
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default plugs
someone posted you can use sirio pllugs on a nova base motor but you shouldn't because the sirio is picco base motor same as Idm motors and has a different tappered angle,
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 11-25-2009, 07:01 AM   #22
Roelof's Avatar
Sirio is Picco based?????????
Old 11-25-2009, 08:36 AM   #23
Yes, from model year 2010 onwards, haven't you heard about it, Roelof?
Both will be made by Novarossi. A cousin of my neighbors uncle who has a colleague that spoke to someone in Italy told me so...
fulcrum2 is offline   Reply With Quote
Old 11-25-2009, 05:47 PM   #24
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
I was a long time Novarossi plug user, until I tried an o'donnel plug, and have never looked back.
Cheaper, glow better, last longer, more consistent, and in my opinion a better quality plug.
Just compare the glow of a new Nova plug against the glow of a new O'donnell plug.
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 11-25-2009, 09:58 PM   #25
last race meet i changed a nova plug, it went well for 5 minutes (i heat) then died. The plug still "works" ie the engien still cranks over but you don't have power, and the engine acts as if it's rich.
Also, the engine sounds louder when the plug is in this state for some reason.
I've used nova plugs all the time without an issue, maybe this was just a faulty one? who knows. But no harm in trying other plugs if they fit.
TomB is offline   Reply With Quote
Old 11-26-2009, 01:32 AM   #26
wingracer's Avatar
Unless something has changed in the last few weeks, Sirio motors are not Picco based, they are made by Star. I have heard that IDM plugs are Sirio's instead of Picco plugs but I do not know if that is true.
What I DO know is, Sirio plugs work GREAT in Nova motors.
Team Shepherd USA
Old 11-26-2009, 07:07 AM   #27
Just the plug taper is the same and also the IDM plugswere made by Sirio at one point in time. There is no relationship of the engine from Picco to Sirio. The taper is different between the Sirio and the Novarossi. This is the difference. The thread pitch is the same this is why they will thread into the head. But the taper itself is what is different. Where it seals into the head.
xspower is offline   Reply With Quote
Old 12-01-2009, 05:34 AM   #28
itchy b's Avatar
I use IDM plugs in my red dot, or should i say used!
I believe that the sirio plugs are compatible to idm jlr picco
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 12-01-2009, 03:56 PM   #29
Yes they are
