-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   Boca or TKO engine bearings? (https://www.rctech.net/forum/onroad-nitro-engine-zone/345002-boca-tko-engine-bearings.html)
KWT-NITRO 11-18-2009 12:10 AM
hi Guys,
i've been asking this question for quiet a long time and got confused because of so many different answers. now, a Pro opinion is needed please to confirm what bearing to go with. i tried bocas on my Siim motor and they dont seem to last long, not as long as the stock sirio ones:weird:. just installed TKOs on my friend's JP eagle and they are still holding good.
so, what do you guys think??
cheers
Ali
wingracer 11-18-2009 10:17 AM
I have yet to try Boca's but I have had very good results with TKO's. I did have a bit of an issue with one of the oddball size bearings but they seem to have fixed that one now.
KWT-NITRO 11-18-2009 01:50 PM
Hi wingracer,
thanks for your answer, and IMHO, if you like the TKOs, dont try the Bocas, i had several in different engines, they didnt last long enough for the price they sell for, no over heating, no bashing, just pro racing, within a gallon, the rear started to have exesive lateral play. well, this my experience with Bocas you might like them.
cheers
Ali
RCHavoc 11-19-2009 02:30 PM
Originally Posted by KWT-NITRO (Post 6616445)
Hi wingracer,
cheers
Ali
I run Boca Bearings in all my engines and I have never had a problem with them wearing out. I just aquired sponsorship with Novarossi, but I was the US Team Manager for the Go-Engine team. I have about 3 gallons through my 7 port and they are holding strong. Still super smooth, no play, no leaks...
aaron joy 11-19-2009 09:56 PM
You might say I'm biased because I am a Boca Bearing team driver but, after dealing with Boca Bearings for the last 2 yrs I will never run some other company's bearings again. Boca Bearing's customer support is top notch, where else can you go to have custom bearings made if need be?
I'm a racer of 14yrs, I can remember seeing Boca's ads 15 yrs ago in RC Car Action. There must be a reason why they are still around.
Try their new MX Series Ceramic engine bearings. I get at least 3 - 4 gallons before I even think about changing them out of my RB engines.
Here is a link:http://www.bocabearings.com/main1.aspx?p=docs&id=34
[email protected] 11-20-2009 04:19 AM
I have been racing with BOCA Engine bearings a full year without failure. I have instaled in RBs, Novarossi, OS, and GRP engines and with great performance and long bearing life. Never needed to try any other brand, Dave
JetMD 11-20-2009 04:24 AM
I have never used Boca so I can't comment on them. But I did put TKO bearings in my JP R3 and I am very pleased with them.
KWT-NITRO 11-20-2009 03:26 PM
hi Guys,
thanks for the answers and comments, well let me start by saying that i'm not against the Boca Company, i run Bocas in Both my NT1s/ MP9 kits. i know that they are THE best bearings for car kits around. i had a bad experience with few engine bearings. maybe its me, maybe its the bearing. i started this thread for this reason, i wanna see if its happening only to me or to many of us!! if i'm the only one to have such problems, maybe i do something wrong that needs to be corrected. thats why i need your advices and opinions.
cheers
Ali
Paulie Bee 11-21-2009 06:40 AM
Originally Posted by KWT-NITRO (Post 6624428)
hi Guys,
cheers
Ali
Hey Ali:
just my humble opinion.....
I've tried and re-tried every type of Boca Bearing for the motors (trying to save a few dollars) they have including the MX versions. I cannot speak to the chassis bearings because I use somthing else on the chassis.
Re the motor bearing only, I have ruined perfectly good motors due to the MX bearings which are supposed to be the best Boca has for the rear. My advice is return to the Novarossi stock-based bearing. Their QC has improved greatly. My .21 motors have had the same rear Novarossi 16002 rear bearing for the last 2 gallons and they are perfect. At the W'Nats, I'll show you how to give your motors maintenance (Italian style) so they last and last!
Paulie
