Old 02-23-2004, 02:47 AM   #1
bleach1's Avatar
Default Motor Maintenance
I have an Os 12tr that has run around 1.5 gallons of fuel through it now in the last 1.5 years. Now the engine still seems to have enough power in it and runs quite nicely but i just wanted to know what sort of maintenance to do on it and when to do it. The only problem i have had is it seems to be leaking between the carb and the block because its always very dirty there are a run. I removed the carby but accidently knicked the metal on the carb. (i used some auto sealant to fix it i hope). Is this a common problem with this engine and what should i look at doing with an engine around this age?
bleach1 is offline   Reply With Quote
Old 02-27-2004, 08:13 PM   #2
bleach1's Avatar
anyone got any maintenance tips?
Old 03-06-2004, 03:45 AM   #3
Nitro Tech
dino.tw's Avatar
You need to change the carb's o-rings to stop leaking.
About engine maintain, you need to replace new conrod;new bearing;even new crank or piston wrist pin regularly. Don't till any part has fault you just want to replace it.
to my experience to mine many expensive .21 engine;
1)When the paly between conrod bushing and crankpin/wrist pin is over 0.05mm,I will change the conrod.If the paly between new conrod bushing and crankpin is still over 0.05mm,that means the crankpin worn out already.I will replace the crank.If the paly between new conrod bushing and wrist pin is still over 0.05mm,that means the wrist pin worn out already.I will replace the wrist pin.
2)I will replace the front bearing every 4 hours running time.
If it is a .21 engine:
4 x 60 = 240 mins.
240 / 5 = 48 tanks.
48 x 125cc = 6L. It's about 1.6 gallon.
3)I will replace the rear bearing every 2.5 hours running time.
2.5 x 60 = 150 mins.
150 / 5 = 30 tanks.
30 x 125cc = 3750cc. It's about 1 gallon.
To remember the records I wrote down to a note,because I have too many .21 like STS;JP;M.Collari;Mega;RB;OPS;Picco....etc. And I have a practicing engine for normal day. A racing engine is only for race meeting. So I never have engine fault on racing day.
Even I sometime may damage my engine due to some carelessness. So be careful with your engine. If it runs good before but runs strange now,stop to run it right now. Your engine is telling you that "Hey master,I'm sick!". Check all parts carefully and you will know what is wrong.
Each racer should have at least TWO engine,if one has problem replace with another engine right now. Don't guess that is just turning problem. It's my sincere suggestion.
dino.tw is offline   Reply With Quote
motor maintenance rexvirtue Rookie Zone 9 06-30-2008 07:06 PM
Motor lot and motor maintenance setup - comm lathe, brush cutter, 27T, 19T, Mod jkas10 R/C Items: For Sale/Trade 5 06-10-2008 07:42 PM
19T Brushed Motor Maintenance Lot! Lathe, motor, spring thing, etc! Cain R/C Items: For Sale/Trade 0 09-11-2007 07:08 PM
Motor Maintenance dvdrsi Electric On-Road 14 02-08-2006 11:56 PM
motor maintenance bleach1 Nitro On-Road 0 02-22-2004 02:53 AM
