Old 03-08-2004, 09:53 PM   #16
EdwardN's Avatar
Originally posted by Grinder
Well, after very very close inspection of the X12 I can say it is longer stroke than the NS12. When I first compared the two it was by eye, when comparing the two with instruments the ports on the X12 and NS are in different positions and the crank pin is higher on the Mugen motor.
What about ID in sleeve (on top)? Is it 13.76 mm or something different?
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 03-09-2004, 07:51 AM   #17
Registered User
junito yukiyu's Avatar
Send a message via MSN to junito yukiyu
so grinder, what are your final thoughs on the motor? is ti worth it??
junito yukiyu is offline   Reply With Quote
Old 03-09-2004, 11:30 AM   #18
stefan's Avatar
Send a message via AIM to stefan
That's strange, because even Nitrohouse has it listed as "X12NS3"
Oh well.....
stefan is offline   Reply With Quote
Old 03-09-2004, 09:01 PM   #19
Grinder's Avatar
Tough to say I have not tried the motor yet. From what I am hearing the motor is faster than NS12. We'll have to wait and see.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 03-10-2004, 04:06 AM   #20
Send a message via AIM to kreidel
So what did you run this past weekend? Also what engine was Nick running?
kreidel is offline   Reply With Quote
Old 03-10-2004, 07:12 AM   #21
Grinder's Avatar
I ran a 6 gallon old NS12. I got home and took it apart and it seems ok, I just had way too much head clearance. Two thick silver shims. Oh well, that won't happen again. Not sure what motors Nick was running. I think Sirio's and Picco's, which I am getting as far away from as I can.
Old 03-10-2004, 07:32 AM   #22
afm
afm's Avatar
I ran a 6 gallon old NS12.. ............................. I think Sirio's and Picco's, which I am getting as far away from as I can.
Hi there Uriah, you got me thinking there with your last statement....., would it be because of the conrod issue on the Sirio's????? or is it because it is a trinity distributed product.
AFM
afm is offline   Reply With Quote
Old 03-10-2004, 08:01 AM   #23
stefan's Avatar
Hopefully both.
Also, the Picco's require some skillz to tune them
Nick's Picco at the Winternats was ballistic though.
Old 03-10-2004, 08:08 AM   #24
2Fast4U2's Avatar
THis is from the Mugen site
* Displacement: .12 cu in (2.1cc)
*Horsepower~1.52 HP @ 41,000 RPM
*RPM~ From approx 4000~43,500
*Stroke~14mm
*Bore~13.8mm
*Ports~3 port
*Shaft~11.5mm
http://www.mugenracing.com/
2Fast4U2 is offline   Reply With Quote
Old 03-10-2004, 09:07 AM   #25
afm
afm's Avatar
*Stroke~14mm
*Bore~13.8mm
*Ports~3 port
*Shaft~11.5mm
Yes we know that, but, by what Grinder has found physically measuring one, it could be a missprint. It would appear that the X12 would be more similar to a Novarossi RRL3 which has a 14.25mm stroke and a 13,7mm bore, which is something that needs confirmation.}
AFM
Old 03-10-2004, 09:10 AM   #26
afm
afm's Avatar
Originally posted by stefan
Hopefully both..........................
Well I just hope it's only a USA problem with distribution and not a permanent problem with conrod issues, because it is a very good engine performance wise. We can allways buy elsewere, as it happens with Novarossi's.
AFM
Old 03-10-2004, 10:27 AM   #27
Grinder's Avatar
The price for Sirio's just went up by about $50.00, with no improvements in the engine. With the con rod issue in the Sirio's and Picco's it's just not worth taking a chance of them breaking during the middle of a race. I will still mod the engines upon special request because they are very fast one race engines, but I will not sell a lot of them.
Old 03-10-2004, 11:41 AM   #28
Registered User
so how good is the x12 in general? , i mean is it woth it??..
Old 03-10-2004, 06:42 PM   #29
Pit-racer's Avatar
Where can I see a detailed pic of the engine and also a parts list for all the engine parts?
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 03-10-2004, 09:13 PM   #30
InitialD's Avatar
Very fast one race engines? I was actually tending to lean more on the Sirio seeing that it's a fast engine and that spare parts and the engine itself are slightly cheaper...
RB .12 R3 RC Review romuald31 Onroad Nitro Engine Zone 2 07-12-2008 02:21 PM
MUGEN MRX-4X REVIEW ocktoberfest00 Nitro On-Road 0 01-18-2008 09:48 AM
any insights or coments abt keyence A07R esc's?? imataquito Singapore R/C Racers 6 07-13-2002 06:50 PM
any insights or coments abt keyence A07R esc's?? imataquito Electric On-Road 12 07-13-2002 03:22 AM
Mugen MSX3 Nitro Touring Car Review KerryG Nitro On-Road 0 03-02-2002 12:41 AM
