Old 01-31-2004, 04:54 AM   #1
Default engine for MT12 p/s and crank
I have a piston and sleeve with conrod and SG crankshaft for MT12. What engine/s will these fit besides mugen MT12?
penggoy is offline   Reply With Quote
Old 01-31-2004, 07:28 AM   #2
stefan's Avatar
Send a message via AIM to stefan
Top TT 12 S1
stefan is offline   Reply With Quote
Old 01-31-2004, 12:37 PM   #3
rod_b's Avatar
Send a message via AIM to rod_b
I think all the Nova based side exhaust engines (except HPI Evo2) are long rod engines and will be able to use those parts.
rod_b is offline   Reply With Quote
Old 01-31-2004, 05:31 PM   #4
Motorman's Avatar
well almost. the piston, sleeve and crank will fit rear exhaust nova type 12,(pre NS and V12 RB) The sleeve can be used in a side port if the alignment pin is removed from the case. the crank will also fit the side port The rod will only fit the MT or a side port nova engine (non hpi evo) Tall deck type.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 01-31-2004, 07:25 PM   #5
nitrodude's Avatar
Since we're on the subject, will a MR12 conrod fit the RBX12? how about the MT12?
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 01-31-2004, 08:24 PM   #6
Motorman's Avatar
yes on the rb no on the mt
Old 02-01-2004, 09:50 AM   #7
so I can use MT12 p/s with conrod and crank on rb rody x12 right?
Old 02-01-2004, 10:06 AM   #8
stefan's Avatar
Noooo, you can use everything but the rod.
Again:
All nova rossi parts are interchangeable, but the rods.
MT12, Top TT12 and NR side exhaust engines have the long conrod, every other engine from NR has a short rod.
Old 02-01-2004, 08:16 PM   #9
thefuzzclub's Avatar
Default Re: engine for MT12 p/s and crank
NOVA S5 will exactly fit.
thefuzzclub is offline   Reply With Quote
Old 02-02-2004, 04:51 AM   #10
stefan's Avatar
except the rod....
Old 02-02-2004, 04:25 PM   #11
Default head button
anybody know if a pico/ofna x-12 head button will work on a mr12 took measurments this morning and the only thing i found was the deck height dia. was 0.01 bigger 13.78 nova to a 13.79
pico ,
isuzuguy is offline   Reply With Quote
Old 02-02-2004, 05:34 PM   #12
afm
afm's Avatar
Default Re: head button
pico ,
Yes. I had to use a Nova Head button on a Picco-Collari and worked just fine, no problem, so i guess the other way around should be fine to.
AFM
afm is offline   Reply With Quote
Old 02-02-2004, 06:46 PM   #13
Default head buttons
thks afm.
What other crank is same as MT12? slufoot78 Nitro Off-Road 1 08-17-2008 10:20 PM
Looking for Mugen MT12 SG crank style cwalters R/C Items: Wanted to Buy 3 10-06-2007 06:30 AM
Can you make a std crank engine a short crank engine? jamiekulhanek Onroad Nitro Engine Zone 3 09-18-2004 11:47 AM
Need Richey Mod MT12 Crank tekrsq R/C Items: Wanted to Buy 2 07-07-2004 03:54 AM
Need turbo crank for mugen MT12 PRO RS4 R/C Items: Wanted to Buy 0 05-30-2003 04:21 PM
