Engine Manufacturers
What is it with engine manufacturers? I ordered 2 engines towards the end of July from the importer who in turn directly ordered them from the manufacturer. We are now in the middle of september and we are about 2 weeks out from our national titles and they still havent packed them to be sent out and i suspect havent even manufactured them. Yes i know it is a world championship year for 8th scale (which these engines are for) but the were ordered 1 full month prior to the worlds!!!! Why is it so hard? :flam ing:: flaming:
Is it the manufacturer, the distributer or the shop causing this problem?
Worldwide you can get engines, I think you are at the wrong shop.....
Trader Rating: 9 (91%+)
A: Must be all those ITALIAN s!@# engine. !!
bearings suck??? explain, I have a friend who uses nova, I use nova base engines and I have trouble with the internal ceramic bearings(11 balls) i change to regular steel bearing(9 balls) and problem desapear, my friend says it something wrong but I see to many complaints about nova bearings, also on the nats at Ohio I spoke with a lot of racer's with the same problem what is happening???
I have two Novarossi plus 12-3SCT motors, one is about 3 gallons and the other one is about 1.5gallons and never ever had problems with bearings or anything. They are 2007 production.
I am guessing you are talking about Sirio?
