Team Orion Alpha .12 factory carb settings?!
can somebody please share with me the factory settings for Team Orion Alpha .12 engine...(2009)
if its ABI Alpha 0.12, its the same as sirio engine i think.
so i have heard, but which of the sirio engines can be compared to team orion alpha .12 engine?
Originally Posted by chrille73
(Post 6247575)
I can also tell you that the needle settings between the two carbs are very different. The high speed needle in the Orion carb is buried much deeper into the housing than with any of my sirio engines. |
Originally Posted by Scott Fisher
(Post 6248684)
Its not the same engine although Sirio does manufacture the engine. While I didn't compare the internals I did ask about our team manager about using the same conrod. He said he spoke to Adrien via email as was told that they don't use the same rod. Maybe thats a load of BS but that is what I was told. I do have an Orion rod coming and can compare them myself to see.
ok...thing is that i am totally lost with the needles right now..really need to find a setting for the carb so that i can start all over again...
Originally Posted by mtbkym01
(Post 6249770)
So Sirio manufacture the ABI engine range?, I thought I read somewhere that they were manufactured by Picco :weird:. I'd be much happier knowing they are manufactured by Sirio :cool:, The ABI has just made my Next engine wish list :nod:
(Post 6252276)
The Orion CRF engine line is made by Picco. The Alpha ABI line is manufactured by Sirio.
(Post 6252647)
Which ones are made in Japan?
So which is faster the alpha or CRF?
(Post 6252696)
Neither. You are thinking about the old CRF line made by Toki.
(Post 6257421)
Ok Thanks, What about the Kyosho X312T?
Originally Posted by Slo-MTX4
(Post 6256425)
May I know what is the data of shimming the turbo head for using 25% and 30% fuel? Thanks in advance.
| All times are GMT -7. It is currently 03:53 PM. |
