Old 08-14-2009, 06:35 AM   #1
nazwenhome's Avatar
Trader Rating: 33 (97%+)
Default Front bearing using normal bearing
what is the consequences of putting normal bearing only on the front part?
tq
Serpent S411 TE : ready to race
Tamiya TA05 VDF : sleeping mode
Align 450 sports v2 : tick-tock in progress
nazwenhome is offline   Reply With Quote
Old 08-14-2009, 06:42 AM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
tq
Instead of a ceramic? Not much.
If you want to use a bearing from a local bearing shop be sure you get a bearing with a plastic cage holding the balls, with a metal cage the lifespan is short and there is a chance of a stuck bearing.
The quality of an answer comes with the quality of the question.
Roelof is online now   Reply With Quote
Old 08-14-2009, 06:49 AM   #3
nazwenhome's Avatar
im planning to use other than os bearing in front. my rear is in good shape. if i use bearing with the plastic cage, would it melt at high temperature?
Old 08-14-2009, 09:05 AM   #4
Roelof's Avatar
If you are using a bearing from another engine it is no problen (if it is the same size).
And no, the plastic cage will not melt (probably it teflon)
Old 08-14-2009, 10:39 AM   #5
nazwenhome's Avatar
new front bearing, here i come
Old 08-16-2009, 08:45 PM   #6
lolgager's Avatar
One question, is it necessary to remove the backside of the plastic cage when installing the front bearing? (leave it open so we can see the inside bearing ball)
|Kyosho RRR EVO2 WC| Shimo's | K Factory | 3 Racing | Asuka Create | Xceed | KM Racing | CSO | DX3R | make.believe
lolgager is offline   Reply With Quote
Old 08-16-2009, 08:58 PM   #7
wingracer's Avatar
Trader Rating: 24 (100%+)
Do NOT remove the cage.
Some bearings have rubber seals on both sides. Most people take the inside seal out but you can leave it in if you want.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-17-2009, 08:32 AM   #8
nazwenhome's Avatar
i left it there next week will be testing the idle
TRF414M, 404x, 414, 414X TRF-Powered Electric On-Road 3600 11-01-2017 07:19 AM
Alex Racing Barracuda R2 & R3 SpeedTech Electric On-Road 14383 08-21-2014 07:06 PM
V-ONE S Thread rhandee Nitro On-Road 4584 07-06-2014 07:19 PM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
Mini Coopers INFERN0 Electric On-Road 30 05-23-2005 11:49 PM
