Palmaris engine thread
Old 03-14-2005, 08:46 PM
  #1351
Super Moderator
Marcos.J's Avatar
Trader Rating: 201 (100%+)
Originally posted by Top Gun 777
For Florida I will sugest to use 0.4 mm or even 0.5 mm shimming. Talk to Peter Breton-he got shims, if not I will send you some.
Needles settings are-pretty lean on bottom and mild reach on top. Use #8 glow plug.
Edward
whats a normal operating temp for that motor?
Marcos.J is offline
Old 03-14-2005, 08:55 PM
  #1352
teammpp's Avatar
Around 220 - 250deg F is normal. But keep it above 190 - 200 and it will be fine.
teammpp is offline
Old 03-14-2005, 08:56 PM
  #1353
teammpp's Avatar
thanks , my friend said that he is sending me shims that came with the motor when he bought it and 2 spare buttons , a turbo ,non turbo and another one that i never heard of
Would that be a nelson oe Globee button?
teammpp is offline
Old 03-14-2005, 09:23 PM
  #1354
Super Moderator
Marcos.J's Avatar
yes that was the name ,a nelson button
Marcos.J is offline
Old 03-14-2005, 09:24 PM
  #1355
Super Moderator
Marcos.J's Avatar
thanks , im running it this weekend!!
Marcos.J is offline
Old 03-14-2005, 09:29 PM
  #1356
teammpp's Avatar
You will probably find you have to gear higher than normal. Maybe 2 teeth on the pinions.
When we first ran them at our local track we pulled the whole length of a sweeper and the straight in first gear. That was just swapping out the engine for a highly tuned Novamega.
teammpp is offline
Old 03-14-2005, 09:32 PM
  #1357
Super Moderator
Marcos.J's Avatar
im running the FW-05R with the Kawahara conversion ,so i should go with 2 teeth less on the clutch bell?
Marcos.J is offline
Old 03-14-2005, 10:42 PM
  #1358
markp27's Avatar
Default Nice package received by post
markp27 is offline
  #1359
markp27's Avatar
Default Re: Nice package received by post
markp27 is offline
Old 03-15-2005, 12:20 AM
  #1360
InitialD's Avatar
Mine came in one day later than yours, Mark. Thanks Chris.
InitialD is offline
Old 03-15-2005, 12:33 AM
  #1361
markp27's Avatar
Default Re: Re: Nice package received by post
Obviously my connections are better
markp27 is offline
Old 03-15-2005, 12:34 AM
  #1362
InitialD's Avatar
Default Re: Re: Re: Nice package received by post
InitialD is offline
Old 03-15-2005, 03:40 AM
  #1363
Ed,
YGPM
CHUCKMANDO is offline
Old 03-15-2005, 03:50 AM
  #1364
kitracer's Avatar
ok , I will use these just for Kyosho cup
kitracer is offline
Old 03-15-2005, 03:59 AM
  #1365
kitracer's Avatar
oopsss forgot pictures.
kitracer is offline
