Old 06-16-2005, 08:37 PM   #1816
stefan's Avatar
Send a message via AIM to stefan
Data,
in anger, I drove it about a year ago , but I went practicing the other day and it didn't look too bad...
Dieter, I am!!!
stefan is offline   Reply With Quote
Old 06-16-2005, 09:27 PM   #1817
kitracer's Avatar
Originally Posted by stefan
Data,
Dieter, I am!!!
Good luck Stefan,
We will have the Serpent Cup this week as well. Palmaris Team here will be up against Max 15 and the likes (but we beat them so many times already )... so you should able to Kick aaaaasssss
Nitro-x Tomorrow Fuel today
Blitz body the champion choice
kitracer is offline   Reply With Quote
Old 06-17-2005, 07:54 AM   #1818
RayJ's Avatar
Default Temp Guns
Data brings up a good point about temp guns. But the Exergen is still by far the most accurate and consistant. Especially when working in max mode. In max mode it measures all temps in the focal point of its view point, and displays only max temp read. Even if the cone is 1/2 inch from glow plug it measures all temps within that 1/2 inch area below. I did read that it is not necessary for the temp cone to be right on contact with the item being measured. The instructions state that the readings will only be off a degree or two. That works for me. The focal point of some of the $30.00 temp guns isn't even close and consistant with the exergens, and they have no self correcting software either.
RayJ is offline   Reply With Quote
Old 06-17-2005, 11:33 AM   #1819
EdwardN's Avatar
Tomorrow will be the first day of the LRP Nitro TC Masters in Luxemburg and Edward's BRB and AAC sets will be in the house
Time to scare some IDM and NOVA Max guys
I hope I still can drive that sucker
Hey Stefan.
Good luck on LRP cup-you know what to do there-just kick some a...s!!!
Edward
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 06-17-2005, 06:51 PM   #1820
Edward- you have a PM.
roostartial is offline   Reply With Quote
Old 06-17-2005, 11:16 PM   #1821
EdwardN's Avatar
Hi Corey-YGPM back.
Edward
Old 06-18-2005, 07:31 AM   #1822
ziggy12345's Avatar
Hi
I ran the BRB set last week and it was a little sluggish. I suppose this was due to bad tuning so I just tried to tune it up. I was running around 240 degF on tick over and it was reving OK but the bottom end was a bit sluggish.
I am running 0.3mm head clearance (1 copper shim in nova engine)
I thought it might be overgeared so changed the 16T on the RRR to 15T and tried again
After refuling it was a different car. It pulled away really well.
When I checked I had mistakenly filled the car up with 25% nitro instead of 16%!!
This makes me think that the head clearance should be reduced a bit for 16% but I am only running 1 copper shim. If i take this out i will be down to 0.2mm. What do you think will this be OK or am i going in the wrong direction?
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 06-18-2005, 09:38 AM   #1823
Ed, you got PM
CHUCKMANDO is offline   Reply With Quote
Old 06-19-2005, 12:19 AM   #1824
Data's Avatar
well......... ?
Data is offline   Reply With Quote
Old 06-19-2005, 07:10 AM   #1825
EdwardN's Avatar
Originally Posted by ziggy12345
Hi
Cheers
Hi Ziggi.
In talking about shimming-yes les head clearnce, higher compression ratio-higher acceleraiton, but many other variables involve. Defenetly with 25% nitro you will need add extra .1 mm shim (compare to 16%), but on some conditions you can leave it alone and it will work just right. I sugest never go lower then 0.3 mm shimming (it is about squishband), just try to work with pipe and clutch settings.
Edward
Old 06-19-2005, 09:34 AM   #1826
Rover's Avatar
Edward,
Can I know how many mm Skyline VR12 stinger are you using for the PR12?
Rover is offline   Reply With Quote
Old 06-19-2005, 10:30 AM   #1827
ziggy12345's Avatar
Thanks Ed.
I ran an outlaw pipe today and it was a lot better. I'll try to get a longer pipe to give me more torque
Cheers
Sponsored by:
Norfolk and Chance
Old 06-19-2005, 10:41 AM   #1828
EdwardN's Avatar
Originally Posted by Rover
Edward,
Hi Rover.
We use only legal pipes, so it is 5 mm stinger.
Best regards
Edward
Old 06-19-2005, 10:44 AM   #1829
EdwardN's Avatar
Thanks Ed.
Cheers
Hi Ziggy
I think you can stay with regular stinger ( what pipe are you using-brand?), and work with clutch and second speed . Is your set still tight?
Edward
Old 06-19-2005, 01:46 PM   #1830
ziggy12345's Avatar
Hi Ed.
The set is still tight. It sticks a little TDC.
I am using RD logics for the nationals. The outlaw pipe was a 6mm stinger. T3 from far east.
I will try to adjust the mid range. The top end comes in a bit quick and as its a lot richer than the bottom the power drops in he mid range. If I screw in the mid range screw this will keep it on the lower needle longer. I know your not supposed to mess with this but it seems the next logical step
Sponsored by:
Norfolk and Chance
Palmaris PR12 .12 1/10 touring car engine boy2rc R/C Items: For Sale/Trade 0 01-29-2007 09:28 AM
Palmaris Racing EdwardN Monster Trucks 0 11-26-2006 08:56 AM
Palmaris Racing EdwardN Electric Off-Road 0 11-26-2006 08:48 AM
Palmaris PS12 engine for sale boy2rc R/C Items: For Sale/Trade 0 08-10-2005 09:05 AM
Palmaris PS12 for sale boy2rc R/C Items: For Sale/Trade 2 03-16-2005 06:15 PM
