Old 04-29-2005, 11:06 AM   #1696
kitracer's Avatar
Originally posted by markp27
Ok, so with the Novarossi built in 0.2mm head clearence, that means the head clearence would be 0.5mm in total - is this correct?
I'll switch to 7TF - anyone need some 6TFs?
Mark, I feel little different on the plug issue. ( sorry if I confused you ) I would stay at TF6 for 16% nitro or even TF5 but I would use 0.3mm head shims ( not head clearance).
I use Magnesisum big (11fins) heat sink even at cold temp ( 10c) which is WAY cooler than JP heat sink and no problem. But as I said, I never really worry about temp unless something not feeling right!
kitracer is offline   Reply With Quote
Old 04-29-2005, 11:08 AM   #1697
kitracer's Avatar
I'm using the JP-FX putty crank - black coated.
Do you think the JP Crank isn't so good with the Palmaris?
definitely not. I am using JP crankshaft ( with little advance timming on closing) and IT IS 1/8 killer on the track. ( at least the OS and Std Nova 21)
Old 04-29-2005, 11:12 AM   #1698
markp27's Avatar
Send a message via ICQ to markp27
Hey Kitracer
When you say a little advanced timing, did you mod the crank? You are of the opinion that the crank should be ok even unmodified - I have one more chance to test before my two races next week *EEK*
markp27 is offline   Reply With Quote
Old 04-29-2005, 11:14 AM   #1699
markp27's Avatar
Ok, I'm switching back to the 0.3mm shim.
I'll test both 6TF and 7TF, as I have both plugs here.
As I say, if the temp said 110C, I would have not have even questioned the performance, as it is there - just the temp confused the heck out of me.
Old 04-29-2005, 11:50 AM   #1700
ziggy12345's Avatar
I would say for a meded crank you need to increase the head clearance as it adds pressure to the cylinder. I was using the normal crank with 0.3mm but i was going to try the JP crank like yours but it rained. Go to 0.5mm and see what you think. I'm sure it will clear up your troubles
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 04-29-2005, 11:57 AM   #1701
InitialD's Avatar
Erm, how? But this would mean I can't alter the timing.
You can map out the exhaust / induction timings by fixing the round protractor onto the crankshaft and rotate to map the duration of the exhaust / induction. Ed gave the details of how you could do this. A typical diagram from rcnitro mag is as shown below;
I got nervous and forgot to enable it
Sloppy...
Old 04-29-2005, 12:14 PM   #1702
kitracer's Avatar
Hey Kitracer
Oppsss.. THe JP crank have more timming than any other Nova based crankshaft that I know ( REX, TOP, MAX etc...) of so thats' Little advanced timming"
The JP crank is good enough for your purpose ( solve the problem), but of course there are rooms for improvement. but I leave it as it is now until I find someone have a faster engine
Old 04-29-2005, 12:38 PM   #1703
markp27's Avatar
Cheers
Cool - I look forward to testing again
Old 04-29-2005, 12:41 PM   #1704
markp27's Avatar
Old 04-29-2005, 12:41 PM   #1705
markp27's Avatar
And I think the driver needs to become faster too
Old 04-29-2005, 01:25 PM   #1706
kitracer's Avatar
O yes, me need to become faster driver too... may the force be with me Yoda
Old 04-29-2005, 01:32 PM   #1707
markp27's Avatar
Forget the force, man - get the Ring
Old 04-29-2005, 02:56 PM   #1708
hi mark,
you life in germany?
if i can help you with timing test, witout a practor, send me a pm or mail
dieter
4racer is offline   Reply With Quote
Old 04-29-2005, 04:27 PM   #1709
EdwardN's Avatar
Originally posted by 4racer
hi mark,
dieter
Hey Dieter. How do you do it without protractor, please send me procedure. I still use old protractor method.
Edward
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 04-29-2005, 05:21 PM   #1710
ed,
you got a email
dieter
Palmaris PR12 .12 1/10 touring car engine boy2rc R/C Items: For Sale/Trade 0 01-29-2007 09:28 AM
Palmaris Racing EdwardN Monster Trucks 0 11-26-2006 08:56 AM
Palmaris Racing EdwardN Electric Off-Road 0 11-26-2006 08:48 AM
Palmaris PS12 engine for sale boy2rc R/C Items: For Sale/Trade 0 08-10-2005 09:05 AM
Palmaris PS12 for sale boy2rc R/C Items: For Sale/Trade 2 03-16-2005 06:15 PM
