strange covered hole in novarossi??
I've taken apart my MAX SL3 for a clean and a bearing replacement and found this hole leading to the front bearing which was blocked with a soft metal material.
does anyone know why this hole is blocked? here are two pics of it unblocked http://i175.photobucket.com/albums/w...1/P1010727.jpg http://i175.photobucket.com/albums/w...1/P1010730.jpg i've seen this hole on an old NS12 novarossi blocked up as well. is this an oil hole? why is it blocked? the hole leads from the entry of the carby where the crank fits through through to the face of the bearing. i unblocked it with a large sewing pin and pushed the material out of the hole and will run the engine soon. here is a pick of the material, it is a soft type metal:confused: same as the material i found in the NS12 a few years ago. http://i175.photobucket.com/albums/w...1/P1010728.jpg i'll be taking apart my XXL3 to see if it has the same hole. I'll probably unblock it as well if i don't see any deterioration in performance or runtime in my SL3 |
Originally Posted by TomB
(Post 6078805)
does anyone know why this hole is blocked? here are two pics of it unblocked http://i175.photobucket.com/albums/w...1/P1010727.jpg http://i175.photobucket.com/albums/w...1/P1010730.jpg i've seen this hole on an old NS12 novarossi blocked up as well. is this an oil hole? why is it blocked? the hole leads from the entry of the carby where the crank fits through through to the face of the bearing. i unblocked it with a large sewing pin and pushed the material out of the hole and will run the engine soon. here is a pick of the material, it is a soft type metal:confused: same as the material i found in the NS12 a few years ago. http://i175.photobucket.com/albums/w...1/P1010728.jpg i'll be taking apart my XXL3 to see if it has the same hole. I'll probably unblock it as well if i don't see any deterioration in performance or runtime in my SL3 This hole must be closed or your engine will be leaking at the fron bearing like nuts. This is some kind of production hole. I opened it up once and it was a real mess. I did stick a tooth pick in it and ciút it of clean, no kidding. |
Originally Posted by stefan
(Post 6078858)
Now you've done it :eek:
This hole must be closed or your engine will be leaking at the fron bearing like nuts. This is some kind of production hole. I opened it up once and it was a real mess. I did stick a tooth pick in it and ciút it of clean, no kidding. i think from memory when i unblocked the hole in the NS12 it didn't hold idle well when entering the pits for a refuel, which would make sense with the whole airleak situation |
(Post 6078858)
Originally Posted by Roelof
(Post 6078939)
Weird. With our engines without this hole we had a leak of oil and with this hole it is gone. It seems to build up or take away some pressure preventing oil to come out of the bearing.
First time I have seen the existence of such hole.... :lol::lol::lol::lol:
Whats the verdict? To unblock or to block it? |
Originally Posted by Riketsu
(Post 6080376)
Originally Posted by JayL
(Post 6080555)
someone open a murnan and that will give the answer :)
Why create that hole and fill it up? Since it is a MAX engine originally made by Novarossi and based on their designs I can imagine Fantini has a different view on it and is this also one of the mods on his engines. |
Erased, never mind
[QUOTE=JayL;6080555]someone open a murnan and that will give the answer :)[/;)
Hmm, heven't been here for while.
Well, no one is answered right for nature of that hole. I will try to help: Look on the second picture and you will see there ie a grove right behind front bearing and this grove is pretty much hydraulic look to keep case hermetically sealed (when cranck is running oil in that griove create sort of barier. But over the time there is a lot of oil collecting and it will start leaking through the front bearing. So prevent oil leaking from front bearing, designers needs to have hole which is going from carburatortor area (which always have negative pressure) to that grove (if you remove carb you will see that end of hole). To make it manufacturable (it is not possible to make internal hole), you will need to drill the hole from front bearing through grove up to undrneath of carb. But now to make it work as sucking pump, the front end of hole needs to be blocked, so it will not suck oil/air from front bearing. Then hole is blocked on the very end of it on bearing side up to the grove. Now you have perfect chanel from carb area with negative pressure to the grove and all extra oil will be back to motor. You need to block the hole as I explaned above, or do whatever you want to. Have fun. |
Interesting. Believe it or not, that actually made sense to me.
Here some pics attached from cross section of my some old design, it will help visualy understand (due to the lack of my engish) the design.
I am very suprized to see all those explanations and no one was even close. BTW, I am out of this hobby and industry and not planning to get back any time soon. I got my self another hobby and enjoy it a lot more. |
Originally Posted by EdwardN
(Post 6082171)
| All times are GMT -7. It is currently 08:25 PM. |
