Old 01-03-2004, 06:53 PM   #1
Default carberator stuck on engine
I'm rebuilding my engine and can't seem to get the carberator off the engine.I've loosened the nut that hold the carb on.I used gaskett sealer when I put it togther.Any ideas would be greatly appricated ....thx
fasteddie d is offline   Reply With Quote
Old 01-04-2004, 10:53 PM   #2
dtm
dtm's Avatar
Send a message via ICQ to dtm
Did you loosen the nut and then "tap" the cross pin?
dtm is offline   Reply With Quote
Old 01-04-2004, 11:41 PM   #3
Yes the lock and nut are loose.I was thinking of heating the crankcase only and see if this works.
Old 01-05-2004, 12:03 AM   #4
Manticore's Avatar
R/C Tech Charter Subscriber
it happens when you locked the cross pin too hard and this will create flash which jam the carb and the crankcase.
i would try to tap the cross pin backward to see if you could restore the carb "neck" shape.
Manticore is offline   Reply With Quote
Old 01-05-2004, 12:06 AM   #5
Fisher890's Avatar
What motor is it?fastharry had that problem with his x12 RB's there is a long thread @ RB forum on it. Alot of fix tips on the matter as well www.rbproducts.com forum .12.
Fisher890 is offline   Reply With Quote
Old 01-05-2004, 03:10 PM   #6
Default Thank you
Thanks to all that answered.rbproducts web site was perfect.just a shot of WD-40 and a couple of turns and it was off.It was so stuck on you could hardly move it 1 or 2mm.
Old 01-06-2004, 12:37 AM   #7
Fisher890's Avatar
No problem glad I could help.
engine mount bolts stuck smb17 Nitro Off-Road 10 08-25-2008 09:56 AM
stuck engine mount cm367700 Nitro Off-Road 16 06-18-2008 05:03 PM
sleeve stuck in engine plz help? downunder23 Electric Off-Road 5 08-24-2006 04:17 AM
Which carberator to use super jato dude Electric Off-Road 3 02-18-2006 06:38 AM
Looking To Get A Nitro ST, Stuck On Engine Choices! etzkev Electric Off-Road 10 05-24-2004 09:29 PM
