Old 06-09-2009, 08:53 PM   #1
Taylorm's Avatar
Default Rear Bearing Removal????
Guys, i can't get the rear bearing out of my mega .21......i put it on a hot plate and got the case to about 300 degrees and it still wont come out......any ideas short of putting it in the oven???.or buying special tools???...........
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 06-09-2009, 11:22 PM   #2
asw7576's Avatar
Special tools.
Old 06-10-2009, 04:35 AM   #3
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
300 Degrees what? 300F or 300C? If its 300F your still way too short. If its 300C, then your doing something wrong. Try putting it in an oven and wait till it reaches atleast 450-500F. Make sure to do this without the carb or the orings will melt.
After you get it that high, wait for atleast one minute till the entire engines reaches that temperature. Afterwards using some heat gloves take the engine out and tap it against something hard (usually the floor) and it will come out.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 06-10-2009, 10:06 PM   #4
Taylorm's Avatar
Nevermin, got it out today....put engine on a hot plate with motor mounts still on.....let it get to about 250..then hit it with a propane torch to about 400 degrees..the bearing plopped right out.........
Old 06-11-2009, 06:52 AM   #5
Riketsu's Avatar
Congrats... Careful with those propane torches. I have seen bearings melt with em.
Old 06-11-2009, 08:33 AM   #6
lil-bump's Avatar
Trader Rating: 83 (100%+)
Make sure when you re-install the bearing; only heat the outside case of the engine. If you heat the bearing directly you probally will melt the bearing races.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 06-11-2009, 04:00 PM   #7
Taylorm's Avatar
......first you put the bearings in the freezer for 24 hours in a ziploc bag to shrik 'em ever so slightly then heat the case.....they SHOULD pop right in.....
Old 06-11-2009, 08:27 PM   #8
Paulie Bee's Avatar
After many years of torches, heat guns, presses and freezers, here is your only real correct answer: go to A main hobbies.com if they still have in stock and invest in this. You will thank me later. Paulie B.
1 x GRP Engine Tooling System Kit (.21/.28) (LOSR0050) = $169.99
Thank You...
SERPENT AMERICA & DESOTO RACING
VP POWERMASTER RACING FUELS, Dean Isaac Paint Schemes,
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
Old 06-12-2009, 02:03 AM   #9
M7H
M7H's Avatar
As mentioned, 300 degrees is not enough, 400 you need atleast....
I always do it this way:
http://www.rbproducts.com/mainEn.php...ncept%20engine
Only instead of a electric plate, I put the engine in the oven, without carb and without any rubber seals in it.
At the same time, I put the crank with bearings as shown in the picture in the freezer, not for 24 hours but as long as it takes to heat up the crankcase...
I don't believe in using a tool to reinstall bearings by force, because it will damage the crankcase and after the 2nd or 3rd set of bearings, they might not be installed tight enough anymore....
But again, this is my feeling, not backed up by proof...
Serpent
M7H is offline   Reply With Quote
Old 06-12-2009, 09:47 PM   #10
Taylorm's Avatar
......absolutely unnecessary........tonight i heated the crancase to close to 300 degrees on a hot plate, removed bearings from a 24 hour freeze and they slid in like bearings slide into a plastic hub carrier.......no tools needed..........
Old 06-14-2009, 10:28 AM   #11
Does anybody know if the GRP Engine Tooling System Kit (.21/.28) (LOSR0050) works only with one main bearing size or all known internal diameters 13.5 / 14 /14.5mm?
Thanks, Stefan
fulcrum2 is offline   Reply With Quote
Old 06-15-2009, 01:10 AM   #12
Roelof's Avatar
Send a message via ICQ to Roelof
If you want a most universal bearing tool set I think the R&B is the best choice. It does support 13mm, 14mm and 14.2mm and since the C9 is using 14.5mm I expect there will be an 14.5mm piece as well.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 06-20-2009, 03:35 PM   #13
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
roelof,
have you seen the c9 yet? how does it compare?
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 06-21-2009, 03:21 AM   #14
Roelof's Avatar
I have seen one and I was not impressed, later I was told he was using the wrong exhaust. From what I have seen (with the wrong exhaust) was that the motor was smooth, did not make any misfire (not picking up to rich ot to lean) but it did not show real power.
Team Associated TC4 Kenshin Electric On-Road 15368 12-15-2017 09:23 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
Bearing removal (beat to death) GSPOT Onroad Nitro Engine Zone 6 06-26-2008 05:02 PM
RB engines are they any good mohamed_own Nitro On-Road 33 10-24-2003 08:41 PM
