Like Tree1Likes
Old 02-20-2011, 02:48 AM   #241
roger999's Avatar
woow great! ill do that with h1 bulb what temp i should expect after 2 min? i mean how hot should be my engine?
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 02-20-2011, 04:31 AM   #242
Lille-bror's Avatar
Hi.
I used this method last easter in 10║ Celsius (50 F). It took 2:30 minute to heat it to 90║ Celsius (194 F).
www.xray-shop.dk www.northtq.com
Best regards Bjarne Petersson, Denmark
XRAY / FX Racing Engines / OS Speed / HPI / Byron / HUDY / Proline / Sanwa MT4s / Sav÷x servos / Ultimate
I miss you Amy...
Lille-bror is offline   Reply With Quote
Old 02-20-2011, 06:28 AM   #243
roger999's Avatar
ok thanks, what after when it will have 90deg temp? what method use for brake in?
Old 02-20-2011, 08:12 AM   #244
Lille-bror's Avatar
The Break in Bible
I miss you Amy...
Old 02-20-2011, 09:32 AM   #245
roger999's Avatar
ok so you mean like in first post here?
Old 02-20-2011, 09:37 AM   #246
Lille-bror's Avatar
Yep, or this which are an updated version:
http://www.rctech.net/forum/7438910-post195.html
I miss you Amy...
Old 02-20-2011, 10:01 AM   #247
roger999's Avatar
ok thanks a million!
just wonder about that second version i mean with car on stand and lots of fuel on full throttle....
Old 03-06-2011, 01:49 PM   #248
watch this http://www.youtube.com/watch?v=26X_s28ilYs
use this method with your micro motors
Ghett0 is offline   Reply With Quote
Old 03-06-2011, 02:06 PM   #249
Roelof's Avatar
Send a message via ICQ to Roelof
The only difference is that those engines have that much precise tolerances that they are almost race ready.
But regarding F1 engines, this is much more fun to run an engine:
http://www.youtube.com/watch?v=1JPBdBIFGNQ
(action in the 2nd half)
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 04-25-2011, 02:41 PM   #250
Should I exchange the piston rod after the break in? or can I still use it? When do you exchange it?
Radiopost TS401
SebO is offline   Reply With Quote
Old 04-26-2011, 12:10 AM   #251
Roelof's Avatar
I do run a 1st race with it and then I replace the rod, at that time it has runned 3 to 4 liters.
Old 05-17-2011, 06:41 AM   #252
ive started already breaking in my engine using my engines manual and already been thru 2 tanks.
Can i stop that and use the heat cycle method or is it too late for me as it seems to be working for everyone ?
thanks
johnii is offline   Reply With Quote
Old 05-17-2011, 08:07 AM   #253
Lille-bror's Avatar
thanks
Hi.
Yes you can. When I got my HPI engine, it has had 1,2 liters through it, and it wasn't even closed to be fully broken-in.
So I startede the break-in all over using the heat cycle. Everything vent great and after 1,5 liter it was fully broken-in.
I miss you Amy...
Old 12-18-2011, 04:32 AM   #254
can anyone tell me what is the most ideal temperature for the engine?...
different brand has a different ideal temperature?...
mr.gabanz is offline   Reply With Quote
Old 12-18-2011, 05:12 AM   #255
Lille-bror's Avatar
Hi.
There are no ideal temp on an engine. You'll have to get the right tune for your specific setup (fuel, glowplug, clutch, gearing, driving style, outdoor temp, body, amount of fuel in the tank etc. etc). Only after that you can make a temperature measurement and get a feeling where your engine approximate temperature should be.
I miss you Amy...
