Old 02-25-2004, 01:26 AM   #106
Originally posted by InitialD
I'll try and run the engine with the given insert and see the performance difference.
Hey, what's your mileage on the Max engine? Pipe model (length), fuel, number of shims, plug number info would be useful. Thanks.
D, the old one has 6mm venturi, and the new is 5.4mm. Both is powerfull fuel sucker but the 3port(new) is better top end.
Big Flowing Track : 6/7TF, .3 shim head, 8" press line, 6mm venturi, 4.5 final gear, NRS-52224(EFRA pipe) it makes 5.17 min. With 110-120 deg.C
Small Technical Track : 7TF, .3 shim head, 6" press line, 6mm venturi, 4.8 final gear, NRS-52607 it makes (just) 6.00 min. With 100-110 deg.C
GoldFinger is offline   Reply With Quote
Old 02-25-2004, 01:58 AM   #107
InitialD's Avatar
Thanks for the info bro. The 3 port NovaMax has better top end?
Yes, I just checked the insert on my NovaMax and it has the 6 mm insert. The other insert which I have is from the NovaMega MS engine. That one printed 5.4 mm on the insert but in reality, it measured only 5.2 mm.
Well, I think I'll try out both and see the difference in power versus tire wear.
As usual, thanks for the accurate info Goldfinger ! What fuel is this? Percent nitro? I assume all of them were run with the insert?
What are the needle settings for the above, if you don't mind me asking? Thanks.
Old 02-25-2004, 02:45 AM   #108
Yup! I think 1 oil pit/groove should means something. The old one have 2 groove in piston
Same here .. ha ha ha .. I believe it was the white one and coming from 2104TMS ??
Byron 16%, insert? yes.. 6mm venturi.
Bit lean in bottom. My driving style is quite smooth (that what my partner says) and I will hold the trigger as much as I can when cornering. That is why i tune my bottom to mid range bit lean so the engine wont goes whroooo.
(Im feeling that you were testing me ?? )
This is a quick check, after top and bottom needle all set. Change the spray bar position (together with low needle) untill your car
can goes Weeeeee (constantly) when you put 10-15% trigger on track. In starter box, when you squeze the triger slowly till max the engine should respond proportionally without any hesitation, especially in mid-range.
Quite hard work to do but believe me! it will pays off in your lap times.
1 more thing, you cannot use an aggresive clutch setup with this kind of engine setup.
Hope this will you bro
Oh ya, me and Pyramid is working alot to put a ball bearing between diff pulley and axle. I will post the result.
Old 02-29-2004, 11:23 PM   #109
Ravi Nair's Avatar
Originally posted by Ravi Nair
have any of you guys tried runnng ts engine without
the venturi. is there any different in performance.
Managed to see the how well ts engine performed. I ran my
engine yesterday w/o the venturi and it was "flying" on the straits. I persoanlly feel it's much easier to tune the engine w/o the venturi.
Ravi Nair is offline   Reply With Quote
Old 03-04-2004, 04:34 PM   #110
Default novamaz 5 ports
Hiya there....
Sound like a silly question, i am thinking of buying a novamax 5 ports, but can anyone tell me will this more powerful than a nova rossi rr12l5 or the nsr 5 ports. The reason is that i haven`t seen one run in the UK yet.
I am running a rr12l5, and this engine is vey quick. I am looking for more power.
Could anybody tell me from experiences how the nova max 5 ports run, i.e, any more torque or power compared with a rody 5 port or the jp etc etc.
thanks
xtreme888 is offline   Reply With Quote
Old 03-04-2004, 09:40 PM   #111
Trader Rating: 4 (83%+)
The Max 5 Ports should be faster than any standard Nova Rossi 12 engines. I have only use the .21 engines, it is probably the fastest engine out there so far.
For the American in this forum. May I ask where you get your Max engine from?
slooookomo is offline   Reply With Quote
Old 03-05-2004, 06:39 AM   #112
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
does anybody know a website which sells novamax engines?????????????????????????
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 03-05-2004, 09:19 PM   #113
thefuzzclub's Avatar
http://www.rcmart.com/catalog/advanc...ort=1a&&page=3
thefuzzclub is offline   Reply With Quote
Old 03-05-2004, 09:21 PM   #114
SupermaxxRich's Avatar
I think www.rc-mushroom.com sells Novamaxx engines?
SupermaxxRich is offline   Reply With Quote
Old 03-06-2004, 01:13 AM   #115
2fast4ya's Avatar
Post
I've seen the performance on these Novamax engines 3 ports & 5 ports and I must say they're pretty damn fast. I was wondering for those who have been running this have you guys had any problems with it? I just wanna find out as much as I can about this motor before I purchase one for my sedan.
Thanks in advance
2fast4ya is offline   Reply With Quote
Old 03-06-2004, 02:26 AM   #116
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Thanks in advance
My problem is that this engine is too fast for MY control ability. seriously, this engine has the power in any range whether in torque & top speed.
One more thing, after like 3 1/2 litres, the pistion/sleeve is still tight. Even my 14.4V starterbox sometimes can't turn the flywheel
Get it...the new one Max S5(based on NSR)...mine the Max P5(old)
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 03-07-2004, 08:20 PM   #117
MX21 MAX MF AAC has landed in HK! Have not fired it up yet. Porting is different. 2 more exhaust ports compares to the ABC version. Same high standard you would expect from a MAX. Polished exhaust ...etc.
Don't know if it will last as long as the ABC version though...
Old 03-07-2004, 08:38 PM   #118
Slooookomo,
Where did you get the new Max from in HK. Do you have a www address for them ?
Old 03-07-2004, 08:51 PM   #119
rc mushroom does not has it up on their site yet. I am sure they can get them. If not try Harmony in HK.
You are in Eurpoe, I thought it would be easy to find MAX there. Where do you get your MAX from?
Old 03-07-2004, 08:52 PM   #120
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Durability is one thing I want to find out from AAC vs ABC.
Ah10 is offline   Reply With Quote
NovaMax MX 12 S3 snemi00 R/C Items: For Sale/Trade 1 08-19-2004 08:58 PM
NovaMAX 15 New! kitracer R/C Items: For Sale/Trade 0 03-30-2004 08:50 PM
NovaMax .21 smash123 R/C Items: For Sale/Trade 1 08-07-2003 06:11 PM
NovaMax .12 smash123 R/C Items: For Sale/Trade 0 06-20-2003 02:07 AM
