Old 04-28-2004, 10:29 PM   #196
Originally posted by jfc_tech
ok...thats a relief...but why diff fuel?
Is tornado ok....but here no tornado 16%...i just wanna use for weekend play...the 16% not for racing though. the 16% is model technic fuel. i use this for my run-in. any comment?
It is not the fuel is bad.
Brand "X" that is reported works very well in Africa, sometimes can not fit in to let say Asia Market (if they dont change the blend).
DIfferent climate, temperature and humidity number is playing biggest part of it.
GoldFinger is offline   Reply With Quote
Old 04-28-2004, 10:36 PM   #197
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Originally posted by mckrooz
Some fuels cause that ugly color to be deposited in your engine. Blue thunder did that to mine. The cleanest burning fuel I've used is O'Donnell.
oic...ok, we have o'donnell here but on the other hand,seems no one using it...especially the new one, in the black tin. the smell is totally aweful compares to others and some bad comments from friends.
i've tried the old one though..with the white plastic container. in fact i used the 25% o'donnell to get to my 1st ever A-main(sorry, can't help it )
i will try anything if it makes my engine last and still performing. thanks for the advice.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 04-28-2004, 10:38 PM   #198
jfc_tech's Avatar
ok...thats logic too. hmm...it seems that i have to try a lot of fuel brand to find the good one. i hope the tornado and o'donnell are good choices.
thanks all.
Old 04-29-2004, 02:21 PM   #199
yes the inside of that engine does look familiar,I have one just like it also using torndao 16%, I was under the impression that tornado was a top quality fuel. Is this orange coating a feature of tornado or all fuels? I don't suppose its a good thing anyway. A good thing would be to open the engine and see a nice clean crisp piston looking back at you.....
NOt sure of the science and only have one other availabe fuel to me which is model technicas, which i though was the lesser of too, however it didnt cause this orange stuff in the engine and alwalys ran well.
wonder why i changed....wonder what to do next?
interesting subject -
However as also stated the engine is running fine.
Neoracer is offline   Reply With Quote
Old 04-29-2004, 10:15 PM   #200
Nova Max .12 Exhaust
Does anybody have tried the new line of exhaust from Nova Max?How is compared to the 2171 from NovaMega?
Paolo M is offline   Reply With Quote
Old 04-30-2004, 12:21 AM   #201
InitialD's Avatar
Default Re: Nova Max .12 Exhaust
Where did you hear this? Pictures?
Old 04-30-2004, 12:30 AM   #202
Ravi Nair's Avatar
jfc_tech-you baby looks ok, not 2 worry 2 much. just do like what
GoldFinger advise and it will be ok. mine was the same and i've cleaned it and it looks as good as new.
Ravi Nair is offline   Reply With Quote
Old 04-30-2004, 02:38 AM   #203
I had a carlsen works engine that looked the same, turns out that tornado fuel has a nasty habbit of attracting moisture when the engine has not been run for a couple of days, my crank and bearings where solid with rust.........
Best thing to do is completely strip the engine including bearings and check that everything is o.k, I would replace the bearings if my engine looked like that inside.....
cheers.....rage
UK_RAGE is offline   Reply With Quote
Old 04-30-2004, 12:29 PM   #204
Default Re: Re: Nova Max .12 Exhaust
I have no pictures but somebody is testing the pipe and seems to work really good.
I found on the austrian novamax distributor the code for this product:
MX00202 NovaMax .12 Inline exhaust + conical header
www.serpent.at is the web site of this dealer
Old 04-30-2004, 11:17 PM   #205
Pyramid's Avatar
SER-2175 Polished Conical Inline Adaptor M12
Newly available from NovaMega is this polished manifold. Due to its conical shape, getting larger from the engine to the pipe, the engines performance is significantly improved in the middle range. A big step forward in engine performance and pipe technology.
Suitable for all .12 engines when used with an inline main pipe.
Pyramid is offline   Reply With Quote
Old 04-30-2004, 11:20 PM   #206
Pyramid's Avatar
I believe you must run 16% for IFMAR
Old 04-30-2004, 11:37 PM   #207
jfc_tech's Avatar
phhhewwww....great. will clean later the day B4 change to new fuel.
thanks for the advice...but i will not strip out my bearing yet...as the engine is doing great...i think its just the fuel deposit. i just clean it as goldfinger adviced. thanks anyway.
Old 05-01-2004, 12:41 AM   #208
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
do u know where can i get it?
Ah10 is offline   Reply With Quote
Old 05-01-2004, 08:35 AM   #209
Check a Serpent dealer in your area or call Serpent USA
Old 05-01-2004, 03:45 PM   #210
I need to replace the conrod on my NovaMax P3, what kind of conrod is it, and can i get one?
Finken is offline   Reply With Quote
NovaMax MX 12 S3 snemi00 R/C Items: For Sale/Trade 1 08-19-2004 08:58 PM
NovaMAX 15 New! kitracer R/C Items: For Sale/Trade 0 03-30-2004 08:50 PM
NovaMax .21 smash123 R/C Items: For Sale/Trade 1 08-07-2003 06:11 PM
NovaMax .12 smash123 R/C Items: For Sale/Trade 0 06-20-2003 02:07 AM
