Old 04-01-2004, 06:40 PM   #166
Default Re: Factory setting
Originally posted by pelos
Does anyone know the factory setting for a Novamax Max3 Turbo?
HSN... near 5 turns out
LSN ... 3 turns out (new 5.4mm venturi)
3.5 turns out (old 6mm venturi)
This is only starting point.
GoldFinger is offline   Reply With Quote
Old 04-01-2004, 08:19 PM   #167
InitialD's Avatar
Default Re: Re: Factory setting
The setting is pretty safe for Novarossi inline pipes. For other pipes, the HSN might just be too lean !
If these settings are to be used for breaking in, I would richen the needles more. Just my opinion.
If I need to tune the engine to race, what I do is best to set the LSN to 4 turns out and HSN to 6 turns out. I do this on most engines. Idle screw is set such that the slide carb is having about 1 mm hole opening when closed. You need to keep throttling to keep the engine running. Set the LSN to lean it till the engine idle RPM goes up a little and then back out a little till the idle remains constant. That should be the ball park LSN setting. Now tune the HSN till you get the engine revving to the highest RPM very easily. Then back out / richen the HSN a little. Test it on track to fine tune.
If the idle is dropping, lean the LSN a little bit more.
Old 04-01-2004, 10:59 PM   #168
Default Re: Re: Re: Factory setting
Thanks bro, for the explanation.. as always
Old 04-01-2004, 11:14 PM   #169
pelos's Avatar
Thanks a lot for the tips.
Last weekend I got lots of problems with high idle rpm only for 10 sec after a zooom. Trying to solve them brought me lost: i first tried to rich the LSN without any noticeable advantage, then I tried everything with my poor experience.
I was running 16% with #5 and 0.3 shim, outside temp 12 C, JPL turbo inline pipe.
I will try your routine tomorrow, thanks again.
pelos is offline   Reply With Quote
Old 04-03-2004, 12:52 AM   #170
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Now im using 16% Model technic fuel...just for play. but the problem is my engine seems to die easily. I know i have 2 tune differently becoz previously using 25%...but really headache. Can anyone suggest me on the HSN and LSN?
Like prev on 25%, HSN 6T LSN 3 1/2T using shark pipe #6, so now 16% HSN=?, LSN=?
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 04-05-2004, 01:24 AM   #171
In genelar, less nitro=less power.
Must compensating it with leaner HSN and or LSN.
Just watch the engine temp, most NS base wont go normal(ideal) at below 100 C (tropical country).
Dies easily.. could be too rich/cold or too lean/hot.
Change the plug accordingly...engine too hot, change to hotter plug/lower number and vice versa...
If still goes wrong... reduce the head shim and or reduce the pressure line length.
Hope this helps.
Old 04-09-2004, 02:35 PM   #172
Omar's Avatar
is this engine a 15 small block http://rc-mushroom.com/product_info....oducts_id=2191
Omar is offline   Reply With Quote
Old 04-12-2004, 11:47 PM   #173
Trader Rating: 4 (83%+)
Finally raced the MX21-MF AAC last weekend. Probably put 4 liters of fuel into it. So far it is still in good shape. Oberservations so far are:
1. Once the engine is run-in, there are almost no nip in it at all. Still runs great.
2. The power band is push into the higher rev. You will need to gear low and slip the clutch a bit.
Will probably put another couple liters on it to see how long it will last. So far there are no signs of wear of liner and piston. The only alarming observation is that the outside of liner might wear out from vibrations rubing on the crank case.
I would think they are a sweeter engine than the ABC version.
slooookomo is offline   Reply With Quote
Old 04-13-2004, 11:50 PM   #174
Default Re: Nova MAX
Originally posted by Ravi Nair
Must we add a head shim (0.3mm) in ts engine. I'm using a 25% nitro. I was runnig a RB X.12 Rody Tune and was advise to add the 0.3mm shim.
I have found no shim in my engine and i hAVE BEEN USING 16% fuel is this bad do i need to ad some shims before i do some damage?
Brett.w is offline   Reply With Quote
Old 04-17-2004, 10:17 PM   #175
Default Glow plug
Could somebody please tell me the correct glow plug code for a nova max 12 3 port turbo i am using 16% nitro in warm to cool conditions
Old 04-18-2004, 12:40 AM   #176
Voodo_Magic... Use the Novarossi C7TGF Med Turbo plug... You're using only 16% nitro and the weather/temp in your area is warm to sometimes cold... The warm plug will work fine. If you step up to a higher nitro fuel, you should move up to a cold plug. Hope the info helps and good luck.
RC_Alan
rc_alan is offline   Reply With Quote
Old 04-18-2004, 04:14 AM   #177
RC_Alan
Hi Alan I cannot seem to find that plug i have been using C5TF at the moment is this the same one?
Old 04-18-2004, 04:48 AM   #178
Hello all.....
I am running a NovaMax in my MTX3 at the Uk foam nationals, 1 of the tracks we race is VERY fast (12 second laps), over half of the track including a banked corner is full speed.
What kind of pipe setup would you recommend for this circuit?
The banked corner is very fast, lots of engines cannot handle the banked corner well and drop alot of RPM due to the load on the car.
Would adjusting the pipe length help keep the RPM stable under load?
thx......rich
UK_RAGE is offline   Reply With Quote
Old 04-19-2004, 01:26 AM   #179
Voodo_Magic... the C5 plug and C7 plugs are different... I would use and warm turbo plug if you can find one. Any major brand will do. If you're running anything below 30% nitro, then use a warm plug... You can use RB's, McCoy's, Top, Rossi, NovaRossi's and Sirio Turbo plugs... Just use the warm ones. I'm sure your lhs can point you in the right direction... Goodluck and happy racing.
RC_Alan
Old 04-20-2004, 09:00 AM   #180
UK_RAGE,
Hi mate,
How do the max peformances compared to the JP or the NSR5.
Reason for asking is that some thieving B*****D stolen my G4 E class with a Nova Rossi RR12L5, head unit, amps and subs from my car last week ! Going to place an order for the G4 E pro from border, hence looking for a new engine as well. Knew that Ben Kensall was running a Rody RB whom FTD as well. Was gonna for a JP FX 5 , but Nova Rossi are bringing out a 7 ports version next week. Is the max have a greater bottom or top end, and how do you rate it to the like of RB, JP or Sirio.
thanks
Xtreme888
xtreme888 is offline   Reply With Quote
NovaMax MX 12 S3 snemi00 R/C Items: For Sale/Trade 1 08-19-2004 08:58 PM
NovaMAX 15 New! kitracer R/C Items: For Sale/Trade 0 03-30-2004 08:50 PM
NovaMax .21 smash123 R/C Items: For Sale/Trade 1 08-07-2003 06:11 PM
NovaMax .12 smash123 R/C Items: For Sale/Trade 0 06-20-2003 02:07 AM
