Old 03-16-2004, 12:18 PM   #151
DickemDown's Avatar
i don't know much about these engines and king from rc-mushroom had suggested this engine for my mbx5.
http://rc-mushroom.com/product_info....oducts_id=1320
i wanted to get some opinions before i pull the trigger. i 've asked around, but noone locally (to me) seems to have any experience or feedback.
DickemDown is offline   Reply With Quote
Old 03-16-2004, 03:05 PM   #152
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
I dont know about buggy engines, but I do run Novamax on both 10th and 8th scale. very powerful engines and they are on par with JP's, M. Rossi, Collari RB's and such
Ah10 is offline   Reply With Quote
Old 03-21-2004, 07:03 PM   #153
Ravi Nair's Avatar
Hi guys....I'm having problem tuning ts engine.....my current setting is HNS 5 turn-out & LNS 4 turns-out with a Shark pipe and plug #6 Tornado 25%. The engine will just stall after 3-4 laps.....temp. ok.
Ravi Nair is offline   Reply With Quote
Old 03-21-2004, 10:40 PM   #154
SlobbaTech's Avatar
Warm the motor up for a few minutes and recheck the idle speed, most of the time it lowers a little once everything is warmed up, have to make sure chassis is warm before doing the fine tuning.
SlobbaTech is offline   Reply With Quote
Old 03-21-2004, 10:59 PM   #155
Ravi Nair's Avatar
thks......
Old 03-21-2004, 11:14 PM   #156
Picard's Avatar
I had the same problem, I put a new plug in and it was perfect without touching the engine adjustment screws
Picard is offline   Reply With Quote
Old 03-22-2004, 01:16 AM   #157
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
we almost has the same setting here and i found the same problem yesterday. it takes me half day to cure it...wasted my time on track. Until, until someone got enough already seeing me on and off the track picking up my car and got pity to me at the end of the day...it was the plug.
the same old plug on the 1st day after break-in the engine..hahhahaha shame on me.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 03-29-2004, 12:11 AM   #158
Default novamax mf15
has any one heard anything about the new .15 by novamax. i seen it on rc-mushroom web site and was wondering if it is worth the price. i drag race and was going to get to novamax 5 port turbo , i saw this and was wondering would this one be better
kpierre is offline   Reply With Quote
Old 03-29-2004, 01:23 AM   #159
InitialD's Avatar
Like others say, check the plug.
If that's ok and you still have problems, I'm just guessing here that I think 4 turns out on the LSN is a little too rich with that pipe. Mine is about 2.5 full turns out if I'm not mistaken. I think your idle is set high to prevent the engine from stalling, correct? Once leaning the LSN and when the engine idle goes up, lower the idle needle.
Old 03-29-2004, 05:30 AM   #160
BaxterC's Avatar
Please guys, take no offense, as I mean none.
The darkside has me it has...
One should change the plug after break-in and dispose of the 'old' plug properly, this was advised by most manufacturers if I'm not mistaken. Rememder that there are many different schools of thought on engine break-in and maintenance, but I will suggest one thing... Run the motor in with the plug you bought it or an equivelent (if you rebuild) and throw it away when the motor is run-in, this will prevent funny things like this happening.
This is just my 2 cents, please take no offence if I sound rude, I dont mean to...
BaxterC is offline   Reply With Quote
Old 03-29-2004, 04:00 PM   #161
Ravi Nair's Avatar
yes you r right, my idle is set quite high.....will try out the above and see how it works.
Old 03-30-2004, 12:41 AM   #162
InitialD's Avatar
Make that a correction. 2 full turns out of the LSN. The last time it was 2.5 turns out, I was playing with the MSN needle which I leaned about half a turn in from the stock flat against the carb body.
Old 03-30-2004, 01:07 AM   #163
jfc_tech's Avatar
BaxterC...no problem. Any suggestion always better than being ignored
For run-in my Max, i changed to hotter plug the Nova #5. Up to 10 tanks or more then only i changed back to Nova #6tF...of which up to now, only 3 plugs im using. The Max is only on its 4-5 litres usage. Still damn tight. worth every penny.
Old 03-30-2004, 08:27 PM   #164
kitracer's Avatar
I have a brand new MAX 15 Like to sell it.
This is the 12 crankcase with 15 Piston & sleeve.
PM me if anybody interested.
kitracer is offline   Reply With Quote
Old 04-01-2004, 07:08 AM   #165
pelos's Avatar
Default Factory setting
Does anyone know the factory setting for a Novamax Max3 Turbo?
pelos is offline   Reply With Quote
NovaMax MX 12 S3 snemi00 R/C Items: For Sale/Trade 1 08-19-2004 08:58 PM
NovaMAX 15 New! kitracer R/C Items: For Sale/Trade 0 03-30-2004 08:50 PM
NovaMax .21 smash123 R/C Items: For Sale/Trade 1 08-07-2003 06:11 PM
NovaMax .12 smash123 R/C Items: For Sale/Trade 0 06-20-2003 02:07 AM
