Old 12-18-2003, 09:33 AM   #16
EVOLUTION's Avatar
Originally posted by Top Gun 777
Man, I would love to, but it isn't mine property and already out of my posetion!
EVOLUTION is offline   Reply With Quote
Old 12-18-2003, 10:09 AM   #17
EdwardN's Avatar
Originally posted by EVOLUTION
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 12-18-2003, 10:36 AM   #18
Manticore's Avatar
R/C Tech Charter Subscriber
Yep,just pack it up nicely in its box and send it my way for tests ASAP !
you are too easy to be satisified !!! OS is not your cup of tea !
Manticore is offline   Reply With Quote
Old 12-21-2003, 03:06 PM   #19
Send a message via AIM to Camaro
Post
I have a os .15 cv-r in my maxx and want to get some more power out of it. If i had the money i would just get a .21 kit but not now. Anything i can do or buy?
Camaro is offline   Reply With Quote
Old 12-21-2003, 05:49 PM   #20
stefan's Avatar
Send a message via AIM to stefan
Edward, check your e-mail, your PM is full
Stefan
stefan is offline   Reply With Quote
Old 12-22-2003, 08:24 AM   #21
stefan's Avatar
Edward???
Old 12-22-2003, 08:34 AM   #22
EdwardN's Avatar
Originally posted by stefan
Edward???
Stefan, please check your PM.
Old 12-22-2003, 08:43 AM   #23
stefan's Avatar
Thx
Old 12-23-2003, 11:23 PM   #24
Is the OS .15 CV-R .. side or rear exhausted ??
Is my presumption correct? :
the .15 CV is side exhaust
and
the .15 CV-R is rear exhaust ??
can't find the specs on the OS website>>>
leo28 is offline   Reply With Quote
Old 12-28-2003, 10:40 PM   #25
Joehwee's Avatar
For 12 size engine only the TR series are rear exhaust, the CV series be it 12, 15 or the new 18 are all side exhaust, the R you are refering to are Recoil = Pull Start
Joehwee is offline   Reply With Quote
Old 12-31-2003, 05:34 PM   #26
WheelNut's Avatar
Send a message via MSN to WheelNut
Hey topgun, how did you decrease the crank case volume? Sounds like a good way to build up more pressure without having to alter the induction port.
WheelNut is offline   Reply With Quote
Old 01-01-2004, 12:34 AM   #27
EdwardN's Avatar
My ittention odecreasing case volume was to increase vacuum and pressure level. But it doesn't mean we don't have to work on induction timing and duartion. case volume and timing realted to each other, but they do different things (we are talking about reasonble difference). I still made induction advanced to compare stock set up ( will like to go further, but not enough meet on shaft). Very important is when it is open and close and it is dictating engine power band and performance. I know a lot of people don't belive in more then 210 degree open on 12 engines, but I belive and do it,on my son's MR12 I have it open 215 and want to do 225, but again not enough meat. On my engine it is much more advanced.
But altering induction without altering the rest of the events will not change a lot, so whole chain of events has to be in siquence and right duration.
I just fill up ports on case with JB weld till the way I wanted to, after that mesured.
Old 01-06-2004, 01:09 PM   #28
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default shims
my o.s. tr came with two shims, i use 20% fuel. If i remove one of the shims will that give the motor more power?or should i just run 30% fuel since the motor has two shims in it?
thanks
Old 01-06-2004, 08:39 PM   #29
Ok just to clarify OS's naming convention:
CV engines .. the original SIDE exhaust
CV-R .. the new SIDE exhaust (R= racing, more power etc)
X= pullstart
(P)= pilot shaft
T= OS's Turbo (use OS's turbo plugs)
cheers
Mark
Old 01-07-2004, 11:39 PM   #30
madweazl's Avatar
I was looking at the TR(P) T (eesh, mouthfull). I've read they make a lot of low end grunt which is appealing to me for a sedan. I was taking a look at their (O.S.) pipes and came across the 1032 which I believe is their top end pipe. If I were to use this pipe would I loose the bottom end the motor naturally makes or would the powerband be widened?
Is the turbo legal to use and most tracks for normal weekend racing?
madweazl is offline   Reply With Quote
O.S Engines thread TTR:EB4 Offroad Nitro Engine Forum 2431 Today 12:37 PM
Official Go Engines Thread MassiveMods Australian Racing 1862 02-13-2012 05:44 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 06:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 11:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 06:00 AM
