Like Tree195Likes
Novarossi engines thread
Old 08-20-2021, 10:11 AM
  #6076
Originally Posted by TurnNBurn
Hi again all - so I managed to get some extra ct6 plugs for the Mephisto, but after seeing a video on glow plugs recently, I needed to ask if anyone with vast experience - given that Im in Florida, Ill be exposed to temperature ranges that will exceed the recommended limits for the CT6 plug. I hope to have my car/engine ready for the Miami GP in December, so I know the plug will be in prime conditions for it, but once temperatures come up in the Summer months, is it better to have colder plugs on hand for 80-90F degree temperatures? Or do people generally stick to the same plug and retune? Thanks!
I have been running my Mephisto with CT6 and CTO6 plugs , 25%/9% fuel in temperature range ftom 15C-40C with no issues at all. I just needed to retune the HSN a hair in or out depending on weather.
TurnNBurn likes this.
GeorgeCk is offline
Old 08-30-2021, 10:16 PM
  #6077
invrtd's Avatar
Trader Rating: 29 (100%+)
Anyone know where to get an x long stroke rod? Any word if someone is going to be making them for those of us who still need them for existing Nova owners.
invrtd is offline
Old 08-31-2021, 01:22 AM
  #6078
Roelof's Avatar
There is no "xtra long stroke rod" it is just an R4 or R7 rod. You can still get these from GiMar and MAX
davidl likes this.
Roelof is offline
Old 09-14-2021, 08:36 AM
  #6079
Captain Howdy's Avatar
Questions?? Novarossi Keep On .21 has no pinch after EBIS
Hi out there I was wondering if someone could share some insight. I have broken in several nitro engines in the past with good results using the heat cycle method. After picking up a Novarossi Keep On .21 I decided to give the EBIS service a try. The engine runs great, stable idle and good power however I noticed that with the plug out I can easily turn the engine over with almost no resistance. I tried this again with the glow plug in and when the engine is warm there also seems to be very little resistance. I'm started to worry the EBIS may have cause premature wear? I understand the difference between compression and pinch but all my other heat cycled engines still have good compression and decent pinch long after break in.
Captain Howdy is offline
Old 09-14-2021, 10:07 AM
  #6080
Roelof's Avatar
Nope, EBIS has nothing to do with that. After the EBIS there is stil a lot of pinch left and you still needed some tanks to complete the break in.
The cold pich does not say a thing about how it is at operating temperature, all has to do with the expansion rates of piston and sleeve. From what we have seen did use Novarossi different piston materials and so in a same engine you can have different pistons, for sure if you have an engine from the last production.
If the engine is going strong then nothing is wrong.
Roelof is offline
Old 09-16-2021, 01:21 PM
  #6081
Thanks Roelof for the insight. I did run a few tanks through it easing into it slowly and brought it to a race tune after another liter or more. You are definitely right about it being one of the last ones as this was the 2020 version. Really sad to hear Novarossi is out of production, especially given the reasonable pricing on these. I'll run this till its dead I guess and when the time comes maybe have it re-pinched.
Old 09-17-2021, 07:12 AM
  #6082
After EBIS it takes more than a few tanks. I do 2 bottles on mine before I race tune it, and Ive never had a problem.
davidl and Captain Howdy like this.
nitrodude is offline
Old 10-15-2021, 10:12 PM
  #6083
Hi everyone, I'm currently running a rex prisma but it's time for a new engine for my Capricorn C03. I'm considering either a Virtus, Mito, or Mephisto. What are your thoughts about each engine. I'm running my car on a larger 1/5 scale track. Any suggestions are appreciated. Thank you.
tc3thatflys7 is offline
Old 10-17-2021, 04:05 AM
  #6084
choisan's Avatar
nova rossi is out of business already. its parts are more expensive than os, maybe it's time for a change
choisan is offline
Old 11-15-2021, 08:01 AM
  #6085
BigC2007's Avatar
Any word on anyone taking over Novarossi or a restart ?
BigC2007 is offline
Old 11-30-2021, 12:30 AM
  #6086
RipModz's Avatar
they sold off all of there machines so it's doubtful we'll ever see a novarossi again
RipModz is offline
Old 11-30-2021, 06:07 AM
  #6087
BigC2007's Avatar
Dang it
BigC2007 is offline
Old 12-13-2021, 08:22 PM
  #6088
Anybody know the size of the Rolling off road rear bearing? Its not the same as the Bonito that i do know.lol
petersen114 likes this.
Ryanne2005 is offline
Old 12-14-2021, 02:07 AM
  #6089
Roelof's Avatar
Better to ask in the offroad section? But it is wise to take the bearing out and measure it....
Roelof is offline
Old 01-08-2022, 05:46 PM
  #6090
petersen114's Avatar
14.5x26x6mm
petersen114 is offline
