Like Tree195Likes
Novarossi engines thread
Old 08-14-2017, 01:35 PM
  #5356
BigC2007's Avatar
Can anyone tell me what this adjustment is for ? I believe this is my 1st engine with this and also what would be a good start point to set this ?
BigC2007 is offline
Old 08-14-2017, 02:11 PM
  #5357
Roelof's Avatar
They call it a mid range needle but basically it is just another LSN. Starting point is flat with the body and leave it
The LSN in the slide can be adjusted leaving the nozzle on the same position, if you turn this one it will act as a LSN but the nozzle will also be re-positioned in the airflow.
So if you screw the slide needle out and this one the same distance in you did not change the LSN setting but did a re-positioning the nozzle that can give a different feeling in the engine.
Roelof is offline
Old 08-14-2017, 02:24 PM
  #5358
BigC2007's Avatar
Understood, again thanks Roelof your the man.
BigC2007 is offline
Old 08-14-2017, 03:34 PM
  #5359
mustangkillaz's Avatar
That's the one I spoke about in my previous post. As R says, flat is the starting point and should only be adjusted by very experienced tuners. It makes a difference in low to mid speed transition.
The adjustment window is very small and you could screw up a tune if you don't know what's going on as you adjust.
mustangkillaz is offline
Old 08-14-2017, 04:15 PM
  #5360
I was looking through an old box of rc stuff and I found a JP Racing 2620 pipe, is it compatible with any of the current .12?
nitrodude is offline
Old 08-14-2017, 11:48 PM
  #5361
dan_vector's Avatar
Trader Rating: 27 (100%+)
Sure it'll be compatible with the current .12's just try it and see how it feels.
dan_vector is offline
Old 08-28-2017, 07:23 AM
  #5362
BigC2007's Avatar
What is the difference between a Novarossi Mito "C" Engine and just a Mito engine ?
Please forgive me but knowledge is limited when it comes to nitro engines.
BigC2007 is offline
Old 08-28-2017, 09:18 AM
  #5363
Roelof's Avatar
Mito C is basically the old Flash. No weird bearing and no xtra long stroke. There is a Mito 35WC which has some differen features And there is a Mito 7 and 9 that has the extra long stroke, weird main bearing and offset carb.
Roelof is offline
Old 08-29-2017, 09:53 PM
  #5364
Trader Rating: 37 (100%+)
Does anyone know what other brands are comparable to a Nova Glow Plug C8TGH?
rip67vdub is offline
Old 08-29-2017, 10:38 PM
  #5365
dan_vector's Avatar
OS RP7 or RP8
Old 08-30-2017, 10:18 PM
  #5366
Originally Posted by dan_vector
OS RP7 or RP8
Thanks Dan!
Old 09-02-2017, 09:42 AM
  #5367
The wc35 sleeve is also different. It's cut shorter at the bottom from what I was told and confirmed upon inspection.
Old 09-02-2017, 08:58 PM
  #5368
OS RP7 or RP8
You can use our plugs GS7 or GS8 (they are made by OS, same as RP7 & RP8)
dan_vector likes this.
desotoracing is offline
Old 09-03-2017, 11:48 PM
  #5369
Anyone have back to back comparisons with mito .12 and new wc version?
Old 09-04-2017, 05:50 PM
  #5370
BigC2007's Avatar
Default Novarossi Exhaust Gas Cooler
Can a Novarossi Exhaust Gas Cooler get clog also like the pipes and need cleaning ?
BigC2007 is offline
