Like Tree195Likes
Novarossi engines thread
Old 02-13-2017, 10:48 PM
  #5206
dan_vector's Avatar
Trader Rating: 27 (100%+)
Originally Posted by mick8488
Hi guys,
I'm considering buying a Mito .12 WC. I have a stock Mito and it runs great, but I was wondering if anyone had experience with the WC version? Is it any more powerful and will it make 5 minutes?
Cheers,
Mick
Hi Mick,
Novarossi's always make 5 minutes. That is one of the many benefits of choosing NR engines. Many other manufacturers are also quick but don't do 5 minutes and so for me is a waste of time. The WC mito is exactly what Dominic Greiner used at the worlds in Gubbio last year to win (many spent days trying to get 5 minutes at the Gubbio track but Dominic had it from the very first run). If you like the stock engine the WC will also impress you.
dan_vector is offline
Old 02-14-2017, 12:06 AM
  #5207
mick8488's Avatar
Originally Posted by dan_vector
Hi Mick,
Thanks Dan, that gives me a bit more confidence. I am also considering a Max Power XP 3.9WE but they're difficult to find and more pricey than the Nova. Do you know much about these engines?
Also, with the Mito WC, the only real difference I can find between it and the stock Mito is it's 10g lighter and has an improved crankshaft for better fuel flow and performance, Nova claims. RPM, bore and stroke are all the same specs. I just don't know if it's going to really be noticeable on the track.
mick8488 is offline
Old 02-14-2017, 05:50 AM
  #5208
dan_vector's Avatar
Lets put it this way Dominic Greiner went from Max Power to Novarossi as he had many of the Max engines fail - the customer support element is also non existent. I also had a buddy who ran Max early last year for a couple ENS meetings and the engines were just flat. You'll be better off with the MITO. Another option could be the Daniele Ielasi Tuned engines and he's just about to release a new engine which is based heavily on the MITO but with his hand tuning. It'll rock!
Old 02-14-2017, 08:21 PM
  #5209
mick8488's Avatar
Interesting. I've been looking into the Ielasi Tuned engines. Their new engine was only just released a few days ago but can't seem to find any info on it just yet. I've had a bad experience with Murnan Modified Novas in the past, primarily because they could not make 5 minutes. I'm concerned another modified Nova would give me the same issues.
mick8488 is offline
Old 03-20-2017, 09:09 AM
  #5210
Its been a while since Ive broken in a Nova 12., a Mito 12A in this case. I started it up and it got stuck once, after that it would start right up. Whats bothering me is that after 4 easy tanks it feels like theres very little pinch, and AFAIR the used to be much more pinch at the beginning. I took it apart fearing scratches, but the piston looks great, it has that dull gray look all the way around, and sleeve looks nice and shiny. Are they faster to break in these days? Im freaking out a little
nitrodude is offline
Old 03-21-2017, 06:42 PM
  #5211
Default Right pipe and manifold?
Just bought a keep off 21-4 with 9901 pipe and 41021 manifold. Running on med size track, technical with turn into jumps,single doubles etc.. and one long 150 ft back raising straight. This combo was suggested by a top local racer. Now reading this form maybe a far better pipe combo??? Lhs hasn't put order in yet
powerpig is offline
Old 03-28-2017, 05:32 AM
  #5212
GrandeGixxer's Avatar
Trader Rating: 21 (100%+)
This is a link to the off road novarossi thread.
http://www.rctech.net/forum/offroad-...hread-629.html
GrandeGixxer is offline
Old 04-01-2017, 07:34 AM
  #5213
mkristanto's Avatar
Default novarossi virtus 21 piston
Hi Guys,
I need help...do you happen to know where I can buy virtus onroad 21 piston only?
I broke the bottom part of it so the sleeve is still good.
thanks
M
mkristanto is offline
Old 04-01-2017, 09:01 AM
  #5214
Roelof's Avatar
Nope, no chance to buy a piston only, you have to get a P/S set.
Roelof is offline
Old 04-07-2017, 01:06 AM
  #5215
Trader Rating: 65 (100%+)
Default Novarossi keepoff 21-7XL +9901+4102
Ok getting back into rc after a long break. I have a novarossi keepoff 21-7XL with 9901 pipe and4102 header new. Going in a mbx7tr. Questions how do the keepoff like to tune anything special? Also I have a square 4105 header. Which would be better? Looking for smooth and fuel mileage. Also my friend that sold me the motor has 5.4 carb venturi in it. I have some old nova carb venturi. From when I use to run a plus4t.sizes 7.0 7.5 8.0 Are they the same for this carb and what size should I run? And finally plugs. Is the C6 still best to use. Any help I would appreciate it. Nobody runs nova at my local track anymore. But i use to only run nova. So that's why I came back to nova. One last thing. How bad does a dented up pipe affect performance. I have a old 9853. In rough shape but i remember it use to make my plus 4s run really good.
mixedguy is offline
Old 04-07-2017, 04:58 AM
  #5216
Originally Posted by mkristanto
Hi Guys,
thanks
M
As long as the pinston still fully cover the exhaust port at TDC, it still can use.
kyosho malaysia is offline
Old 04-25-2017, 03:40 PM
  #5217
Hi Guys,
We have Novarossi products in stock. Check us out
RCtarget is offline
Old 04-26-2017, 03:00 PM
  #5218
BigC2007's Avatar
Default ? On glow plug
For the FLASH .21 PT/A calls for a Glowplug: Turbo (C8TGH) From my understanding this is a very cold plug I was told its better to run #7 or even a #6 so I just wanted to verify.
BigC2007 is offline
Old 04-26-2017, 03:20 PM
  #5219
Roelof's Avatar
With standard shims and 25% or more nitro you have to run the 8 plug, a 7 can be too critical to stay alive at a sharp tuning.
Roelof is offline
Old 04-26-2017, 06:13 PM
  #5220
BigC2007's Avatar
Thanks Roelof for the info.
BigC2007 is offline
