Old 02-11-2005, 07:49 AM   #1426
speedy2's Avatar
what about the D.21 motor?
anyone got one ?
speedy2 is offline   Reply With Quote
Old 02-12-2005, 07:22 PM   #1427
Nitro Tech
dino.tw's Avatar
Default Re: Re: Re: D5R Variation
Originally posted by dameetz
Sorry if I m confusing, let me explain again. Me and my friend have D5R, which is a 5 ports engine, which looks the exactly the same from the outside. However, upon inspecting the sleeves,they are both different. As I said earlier my sleeve looks like normal typical 5 port with both side 2 transfer port and 1 booster port, my friend's is like a Nova sleeve with both side 2 transfer ports (one vertical and one is normal horizontal) and the booster port has a divider or wall in the middle, which if you count will make 6 ports instead.
That is six ports .12 engine. Only produce a few for team racers. Due to the cost is higher and no one want to buy high price STS engine,so we didn't release it officially. The original we would like to upgrade the D5 to D6,after some market analysis we knew that people only want economical racing engine. So we just stop the plan and change direction to lower the prices.
dino.tw is offline   Reply With Quote
Old 02-13-2005, 07:34 AM   #1428
dameetz's Avatar
Default Re: Re: Re: Re: D5R Variation
No wonder that my friend's D5R is a bit faster than mine. Anyhow, I m more than satisfied with my normal D5R. FYI my friend I m talking about is Hj Irman from Brunei, he got the motor during Femca Race last year in Thailand.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 02-14-2005, 06:25 PM   #1429
::TEAM SRGS::'s Avatar
l have a sts have you peaple have any pics on mods done to a sts
Nikon D300
Olyumps E20
nikon lens
28mm
185mm
300mm
::TEAM SRGS:: is offline   Reply With Quote
Old 02-17-2005, 03:14 PM   #1430
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Dino did the carb have a leak
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-17-2005, 03:43 PM   #1431
I once had a leak on my D5 carb - caused by me moving the fuel inlet
au_Nightmare is offline   Reply With Quote
Old 02-18-2005, 01:19 AM   #1432
Nitro Tech
dino.tw's Avatar
No. But I still send a new carb to you.
Old 02-18-2005, 05:36 AM   #1433
hi dino! sent you a PM..
OrAnGe PoWeR is offline   Reply With Quote
Old 02-18-2005, 11:46 AM   #1434
20 SMOKE's Avatar
thanks
Jamie W
Old 02-21-2005, 01:23 PM   #1435
HI Dino
what is the size of STS D5R engine's bearing
thks
A380 is offline   Reply With Quote
Old 02-21-2005, 01:43 PM   #1436
afm
afm's Avatar
Originally posted by A380
HI Dino
thks
PN 202 Front bearing 7x19x6mm
PN 120201 Rear bearing 12x21x5mm
AFM
GPP Model Racing
afm is offline   Reply With Quote
Old 02-21-2005, 02:24 PM   #1437
Thanks AFM
Old 02-21-2005, 10:20 PM   #1438
Send a message via Yahoo to Vegas Racer
Thumbs up
Can someone tell me what the optimum operating temp is for the D3? I am running one in my Vision Pro and racing this weekend.
Thanks,
Mark
Vegas Racer is offline   Reply With Quote
Old 02-22-2005, 12:42 AM   #1439
Dino or AFM give the best answers but ill throw my 2c in.....
The correct temp is great performance tune with visible smoke from exhaust
IMO you should only check temp to ensure ur not over cooking it. Engine temp will depend on weather, track, fuel etc so you can not really tune to a magic temp value.
Just do not try over rev her - gear it up if required.
Old 02-22-2005, 05:51 AM   #1440
afm
afm's Avatar
Thanks,
Mark
There are many variables that affect it; Ambient temp, fuel type and nitro content, altitude & barometric pressure, Pipe/manifold type and setting, clutch setting, glow-plug, gear ratio, available traction, How hard your driving, Etc. Etc.
All of the following conditions MUST be met before any temperature can be considered correct, assuming the engine is in good shape.
1.-There must be a visible trail of smoke when accelerating from EVERY corner.
2.-The idle is stable.
3.-The glow plug wire and surrounding bottom of plug dry, wire somewhat shiny, almost gray but the coil stays round (UN - DISTORTED) = Optimum power 100%
4.-The performance is good, and does not decrease along a tank of fuel.
Actually when a new plug wire just goes slightly gray after a 5 or 10 minute of hard run, it means you are very close to an optimal horsepower tune, but be careful the next step is TOO LEAN!
Note: You can only "Read" your plug in a nearly new state (Wire like new and shiny). A gray plug can still operate well. But after it has totally gone gray performance can start to fall off. To test just put in a new plug and if there is no difference in performance save the gray one or put it back in. If your engine does not feel or run right try a new plug before making major tune change's
If the optimum conditions are met according to above explanation, the Dragon D3R should read a Temp of around
100 - 120C, based on Air Temp of 25 - 28C at sea level.
AFM
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
