Old 02-06-2005, 08:22 PM   #1411
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally posted by dino.tw
20 SMOKE,is it a stock D3R or someone has modified it?
ProjectZen mod
how about the scraping /burnmarks on the p/s
copper .28
alum.38
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-06-2005, 08:28 PM   #1412
Nitro Tech
dino.tw's Avatar
Originally posted by 20 SMOKE
ProjectZen mod
how about the scraping on the p/s
That is why I ask you anyone mod it. They change the port timing also?
two possible;
1)there are some deckle edge after mod
2)too lean when break in will cause scratch too
dino.tw is offline   Reply With Quote
Old 02-06-2005, 09:27 PM   #1413
afm
afm's Avatar
ProjectZen mod.............
copper .28
alum.38
That is to much alu 0.38mm??? copper 0.28mm??
A total of 0.66mm shims???, that's good for 40% Nitro
You sure you measured right, because to low compression on a particular Nitro% can cause overheating too.
I'ts curious that you have extra 0.008mm on both measurements of shims, plus I only know of 0.10, 0.20, 0.30mm shims.
Check and correct accordingly, you should use 0.50mm total on 30% Nitro, and Nova 7TGF plug.
AFM
afm is offline   Reply With Quote
Old 02-07-2005, 05:16 AM   #1414
20 SMOKE's Avatar
the markings on the p/s came later after I got back from Geoff. I sent it to him and he did a few more things to it so i will do the clutch and find new head shims to.
Jamie W
Old 02-10-2005, 03:57 AM   #1415
Hello from Spain. Sorry for my english
I bought a STS Dragon D3R modified, by rc-mushroom
Can you say me the specification for this engine (hp, rpm...). In the STS web donīt put this.
How I can do the break in, by 15% fuel?
Oscar
ojerez is offline   Reply With Quote
Old 02-10-2005, 04:11 AM   #1416
TRAJ's Avatar
Hello
i dont know about the engines HP or RPM but if you read this it tell you how to break in the engine
click here : http://www.rctech.net/forum/showthre...threadid=49711
TRAJ is offline   Reply With Quote
Old 02-10-2005, 04:28 AM   #1417
ziggy12345's Avatar
Originally posted by afm
For 30% nitro I'd use Nova 7TGF plug.
For 30% Nitro I'd use total 0.50mm shims, so if you say you have 1 alu, which is 0.30mm, the copper should be 0.20mm, but you must measure the copper one you have on, because there are thiner ones.
AFM
You want to wantch the head clearance. It has some clearance withut any shims and so the head clearance is not the shim thickness.
The only way to check is to stick a piece of solder in the chamber and turn over the engine then measure the flattened end. Add or take out shims as required.
The NSR .12 is 0.008" without any shims
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 02-10-2005, 06:02 AM   #1418
afm
afm's Avatar
Cheers
Thanks, but my reccomendations are allready taking into account clearance without shims.
Your method of checking unshimmed head clearance is very unprecise.
The correct method is dissasembling the head and measuring head and cylinder recess with a depht micrometer or a digital caliper, then substract both measures and add shims accordingly to arrive to proper combustion chamber size.
AFM
Old 02-10-2005, 08:49 AM   #1419
ziggy12345's Avatar
Where are you assuming the piston comes to? How will you know this by measuring the cylinder head recess?
My method measures the ACTUAL head clearance. It also puts force on the piston to remove all play so is close to what would be the measurment under compression.
Cheers
Sponsored by:
Norfolk and Chance
Old 02-10-2005, 08:54 AM   #1420
dameetz's Avatar
Default D5R Variation
How many types of D5R is out there? I m asking because mine does not look the same as my friend's. His sleeve porting looks like a Nova ( with vertical inclined transfer port) but with a divider at the booster port. Mine is looks a bit like OS/RBV12 ( with 2 normal transfer port and no divider at the booster port.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 02-10-2005, 09:45 AM   #1421
afm
afm's Avatar
Cheers
Piston has to be at TDC of course, then measure depht from cylinder edge to piston crown. It is very simple.
If your method works....good for you. I prefer the micrometric measurement.
AFM
Old 02-10-2005, 09:58 AM   #1422
afm
afm's Avatar
Default Re: D5R Variation
Little bit confusing your question. Let's see 5 port engines have 2 side transfers and one boost transfer at the opposite end of exhaust port. The side transfers are divided in two by a bridge, so that makes 4 side transfers, plus the boost makes 5.
3 port engines have no dividing bridge on the sleeve side transfers, so that makes 2 side transfers plus boost transfer.
Now STS 3 port D3R engines have an aluminum bridge on the crankcase paths to both side transfers and boost transfer...and somehow aids mixtture flow simulating more ports. I haven't seen physically a 5 port crankcase to see if thy have them too.
I hope I'm clear on my explanation.
AFM
Old 02-10-2005, 09:34 PM   #1423
dameetz's Avatar
Default Re: Re: D5R Variation
AFM
Sorry if I m confusing, let me explain again. Me and my friend have D5R, which is a 5 ports engine, which looks the exactly the same from the outside. However, upon inspecting the sleeves,they are both different. As I said earlier my sleeve looks like normal typical 5 port with both side 2 transfer port and 1 booster port, my friend's is like a Nova sleeve with both side 2 transfer ports (one vertical and one is normal horizontal) and the booster port has a divider or wall in the middle, which if you count will make 6 ports instead.
Old 02-10-2005, 10:28 PM   #1424
so your side ports look like "- -" but your friends is "- |" and your booster port is "---" where your friends is "- -" ?
au_Nightmare is offline   Reply With Quote
Old 02-11-2005, 05:09 AM   #1425
dameetz's Avatar
Thats right I don't have dig camera yet so can't post the pic.
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
