Old 02-02-2005, 10:40 AM   #1381
afm
afm's Avatar
Originally posted by 20 SMOKE
Afm are you going to have a modded version also or just what the factory does to it
Yes, we will have a special ROAR- IFMAR moded version. The factory modified D3R is EFRA legal, which leaves us a window to work over. We are currently doing testing on pilot engine.
AFM
GPP Model Racing
afm is offline   Reply With Quote
Old 02-02-2005, 12:55 PM   #1382
Originally posted by Finken
Well, if you can find any of theese products at a 40% discount, please let us know........becouse YOU WONT!
Easy: Nitro shoes, where $15 now $8.70 - thats more then your 40% "I wont find"
Ive also seen bearings at 50% off - that to me means it is time to stock up, not run away...
Anyway these engines are great but I think you should get something else, something thats never been on special
au_Nightmare is offline   Reply With Quote
Old 02-02-2005, 02:01 PM   #1383
nils's Avatar
Default factory carb setting
hello dino ,can you tel me what are the factory settings of the
carburetor.d3r zen mod.
im breking in a new piston sleve set.
i dont now the original carb settings enny more.
nils is offline   Reply With Quote
Old 02-02-2005, 04:13 PM   #1384
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
AFM
GPP Model Racing
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-02-2005, 04:14 PM   #1385
20 SMOKE's Avatar
Default Re: factory carb setting
They told me rich on the bottom lean on the top I would go 5 bot 3 top
Jamie W
Old 02-02-2005, 08:22 PM   #1386
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Default Oil Leaks in the front bearing?
Just decided to get back to nitro touring and is really leaning towards getting the STS D3R from RC-Mushroom as they are on special. Just want to find out if the front motor bearing have any problems with oil leaks during running compared to the Italian mills.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 02-02-2005, 09:18 PM   #1387
Send a message via ICQ to noobatron
Default D5R moded internals
Hey guys,
recently i brought brand new D5R internals including Piston, Liner, the new silicon crank, front bearing and all 3 (version 2) needles. The crank has had it's timing moded by ProjectZen.
So this will make it faster than standard D5R.
However, due to the closure of my local circuit and work commitments, i'm not going to be able to reap the performance benefits from these. I'm putting all my RC gear up for sale on ebay but wll be offering this here if anyone is interested.
Items BNIP, i payed a fair bit for them so my loss is your gain
$100US
noobatron is offline   Reply With Quote
Old 02-02-2005, 09:23 PM   #1388
I just replaced my front bearing in my D5 because it started leaking, engine is about 1 year old. Replacing beaing was a lot easier then I thought it would be though I cheat - got the bearing puller kit (& bearings) from Mushroom
Old 02-02-2005, 11:15 PM   #1389
afm
afm's Avatar
Default Re: Oil Leaks in the front bearing?
This is what Dennis Richey has to say about the bearing issue, and he works with the RD Logics RRE engine made by STS for them.
AFM
(quote)
I see a lot of talk about bearing leakage these days, so let me dispel a myth. They all leak slightly no matter what your running these days. The long intake timing and short pipes everyone has gone to get smoking performance causes this. The blow down and subsequent pressure rise in the crankcase causes a small amount of fuel to be pushed out the front, and if you run the engine to rich it will really leak. The other issue is that at the rpm the engines run, the seal can go away really fast. I used to keep replacement seals in my box and changed them as a maintenance Item on my Novas. Thatís just the way it is
(unquote)
Old 02-04-2005, 08:39 AM   #1390
kitracer's Avatar
Default dino's resturant
Hey Dino, when did u start the food business
kitracer is offline   Reply With Quote
Old 02-04-2005, 12:42 PM   #1391
Looks like nice place Dino, well done!
Old 02-04-2005, 05:16 PM   #1392
20 SMOKE's Avatar
Default Carb
Dino you should get by Friday or Saturday
Jamie W
Old 02-04-2005, 09:06 PM   #1393
Nitro Tech
dino.tw's Avatar
Default Re: dino's resturant
hum! ..... Is it good to eat?
dino.tw is offline   Reply With Quote
Old 02-04-2005, 09:08 PM   #1394
Nitro Tech
dino.tw's Avatar
Default Re: Carb
OK! If it doesn't arrive today,I will receive it on 14,Feb.
Old 02-06-2005, 04:55 AM   #1395
AMGRacer's Avatar
Had several flameouts with my D3R few weekends ago, i put it down to it being worn out. Pulled the plug out today and I noticed that the coil was pushed in to the body of the plug. Also it was broken in one place.
I have never had this happen before looking for some answers why this may happen. It was not over compression, the standard shims are being used. Fuel is good quality 16% nitro content.
AMGRacer is offline   Reply With Quote
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
