Old 12-04-2004, 07:54 PM   #1291
HI Guys,
I just installed my D5 in last week to a v1rr. I have been running it in, I've probably gone through a bout 1 litre. I was using a nova turbo hot long body plug and found that it would flame out when it was running in the top end. I'm using 15% nitro it's got a bit of oil in it. The temperature was in the 20C's and running on .3 shim. I changed the plug to a cold one and it didn't flame out in the top end, idle was a bit high so adjusted the idle screw.
The engine is pretty good, but still running it in. I can feel some friction still at TDC when i take the plug out. Engine is running around 190-218C.
Do I have to run it in for around 2litres or can i start to lean it out a bit when the friction is not there at TDC?
I've ordered a D3 p/s but couldn't find the conrod for a sts .12 only for the .21 at rc-mushroom. Will the .21 conrod fit in the D5? I've got a spare conrod that I bought with the engine and I was going to put it in after break in.. So i will have to buy a new rod when i start to use the D3 p/s
Jason.
ieie is offline   Reply With Quote
Old 12-04-2004, 11:07 PM   #1292
What is the recommended glow plug for the D5?
Thanks,
Bruce
slawsonb is offline   Reply With Quote
Old 12-04-2004, 11:18 PM   #1293
If there is only *slight* friction I would look at start leaning..
Email Rc-Mushroom - They used to list the .12 conrod but seem to have missed it when they reloaded their engine parts into the website. The .21 conrod is massive and will not fit.
au_Nightmare is offline   Reply With Quote
Old 12-05-2004, 07:47 PM   #1294
Nitro Tech
dino.tw's Avatar
Dear Jason,
Please more patience if you want it durable. 218F is ok for air temp 68F.
dino.tw is offline   Reply With Quote
Old 12-05-2004, 07:51 PM   #1295
Nitro Tech
dino.tw's Avatar
Thanks,
Bruce
Dear Bruce,
OS P6 or Nove #6. I only use white iron body glow plug.
Sorry,I click wrong button.lol...
Dino
Old 12-05-2004, 08:21 PM   #1296
Thanks, Dino.
Is that the Nova C6TC? I am running 30% nitro so would the C7TC be better?
Bruce
Old 12-05-2004, 08:27 PM   #1297
Nitro Tech
dino.tw's Avatar
Thanks, Dino.
Bruce
If it easy flame out,use hotter plug. Colder plug more durable.
Old 12-06-2004, 01:40 AM   #1298
Cool D21B
Hi to all
I just ordered a D21B for my Hyper 7.
Should I use the same type I am currently using? (3 shoe stock)
I also use Byron 25%. What plug do you recommend?
I have access to OS5,OS8, SH 5,6.
Thanks in advance.
sts2000 is offline   Reply With Quote
Old 12-07-2004, 12:36 AM   #1299
revzalot's Avatar
Default Break In Procedures
Is it okay to break in an STS engine at WOT after it reaches operating temperatures? I've read this link about how WOT is beneficial for breaking in an engine intially.
The Link
www.revzalotmotorsports.com
revzalot is offline   Reply With Quote
Old 12-07-2004, 10:08 PM   #1300
Nitro Tech
dino.tw's Avatar
Default Re: D21B
Originally posted by sts2000
Hi to all
Thanks in advance.
3 shoe type has better low end. And you need to cut the shoe for light weight. The shoe and spring always die fast,so you need to stock some of them. Also 5x10 bearing.
If the weather is cold,use hot plug. If the weather is higher than 20C,use middle plug. When the weather is higher than 30C,you can try cold plug. Hotter plug more stable and easy to adjust. With Byron25% you can try 0.3mm head shim first. If it eat your plug,then put on 0.1mm extra shim.
Old 12-07-2004, 10:13 PM   #1301
Nitro Tech
dino.tw's Avatar
Default Re: Break In Procedures
The Link
WOT is a faster way to break in engine. But if your fuel has not enough lubricity,it may damage your crankpin and conrod. I will only use WOT way on the first tank. This way can fully clean your engine. Then just run on the track slowly and start to lean it each tank.
Old 12-08-2004, 09:25 PM   #1302
What is a good initial carb setting for the MT-12?
Old 12-09-2004, 11:37 PM   #1303
Dino? Anyone?
Old 12-09-2004, 11:59 PM   #1304
Nitro Tech
dino.tw's Avatar
You can try this first;
top end needle 4 turns out
low end needle 4 turns out
mid range needle flat with the mount
I will lean the top end a bit and rich the low end to 5 turns after break-in.
Old 12-10-2004, 12:19 AM   #1305
Thanks Dino!
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
